  • March 20, 2019, 04:34:34 AM
Pages: 1 [2] 3 4 ... 6
Author Topic: Service/User Manuals  (Read 40484 times)
seanuk
    • http://www.autobitzonline.co.uk
Re: workshop/service manuals
« Reply #10 on: May 12, 2007, 09:30:01 PM »
Quote from: "wnp_uk"
i got a disc with the manuals for i think all hyosung bikes..
the disc cost me £30 so i want 2 get some of the money back , for £3 ill email/messanger you the files for a certain model and for £5 ill post u a copy of the cd
Why would i pay £3, when I can download them here for FREE  :!:  :!:
wnp_uk
« Reply #11 on: May 13, 2007, 12:54:40 PM »
were can you download them for free ?????? :?:
i think you'll find no were ....
the only manuals on this site are for the comet ...not any of the other hyosung models ....
y dont you people read the posts befor posting a stupid reply ?????? :pissed:
Michelle
all i can say is
« Reply #12 on: May 13, 2007, 01:02:09 PM »
E-bay.Search under Manuals and literature
wnp_uk
« Reply #13 on: May 13, 2007, 01:33:14 PM »
yeah they are on ebay thats me selling them now ......
they arent free and there's no cheaper email option "!!!!! :pissed:
Mike on the Rock
    • www.seaies.com
« Reply #14 on: May 13, 2007, 02:38:19 PM »
FREE AT
http://www.hyosungmotorsusa.com/Download/Download.asp?page=1
and
http://www.hyosungmotorsusa.com/Download/Download.asp?page=2&strSearch=&chkSubject=&chkContent=
and the other sites mentioned in this thread :clap:  :clap:  :clap: FREE AT
Ride safe Mike on the Rock
All my Rides are Naked.
http://seaies.com
wnp_uk
« Reply #15 on: May 13, 2007, 04:14:27 PM »
LOL ........wot is wrong with you lot the sites you have all listed do not have the workshop/service manuals for the :
GT 650
GT125
GT250
GV125
GV250
GV650
RT125
RX125
thay may have the manuals for the odd 1 or the parts manual but that isnt the same as a serveice manual ........
seems alot of people have difficulty reading !!!!!!!!!!!!!!!!!!!
any1 else going 2 add a site that has the manuals so far thats like 5 people that are incorrect !!!!!!!!!!
seanuk
« Reply #16 on: May 13, 2007, 05:30:45 PM »
Could you show me a couple of screen shots of the workshop/service manual for the GT650R
wnp_uk
« Reply #17 on: May 14, 2007, 03:35:09 PM »
Quote from: "seanuk"
why do you want me 2 do that when u were saying you can download them for free ???????  wrong was u ?????
told you iv been shearching for ages and cant find them anywere !!!
£3 is a small fee i payed £30 !!!!!!!!!!
i dont actualy know how screen shot it as there in adobe reader format ..
here;s the first page i copy and pasted...
 :arrow:
This manual contains an introductory description on
HYOSUNG 『』& 『』and
procedures for its inspection/service and overhaul of its
main components.
It covers the differences from『 』and please
refer to the service manual of『 (99000-94810)』
for others which are not covered in this manual.
This page numbers on the top are ones which are in the
service manual of『 』and ones on the bottom
are the page numbers in this manual.
Other information considered as generally known is not
included.
Read GENERAL INFORMATION section to familiarize
yourself with outline of the vehicle and MAINTENANCE
and other sections to use as a guide for proper
inspection and service.
This manual will help you know the vehicle better so that
you can assure your customers of your optimum and
quick service.
VALVE CLEARANCE
The valve clearance specification is different for
intake and exhaust valves.
Valve clearance adjustment must be checked and
adjusted,
1) at the time of periodic inspection,
2) when the valve mechanism is serviced, and
3) when the camshaft is disturbed by removing it
for servicing.
● Remove the spark plug. (Refer to page 2-5)
● Remove the fuel tank. (Refer to page 4-1)
● Remove the radiator. (Refer to page 5-2)
● Remove the cylinder head cover bolt ① and ②.
● Remove the magneto cover plug ③ and the timing
inspection plug ④.
0.1 �� 0.2 mm (0.004 ~ 0.008 in)
0.2 �� 0.3 mm (0.008 ~ 0.012 in)
IN.
EX.
Valve clearance Standard (When cold)
Thickness gauge : 09900-20806
● Rotate the magneto rotor counter-clockwise to set
the front cylinder’s piston at TDC (Top Dead
Center) of the compression stroke.
(Rotate the rotor until“ |F”line on the rotor is aligned
with the center of hole on the crankcase.)
● To inspect the front cylinder’s valve clearance, insert
the thickness gauge to the clearance between the
camshaft and the tappet.
Inspect Interval
Inspect Initial 1,000 km and Every 6,000 km.
CAUTION
The clearance specification is for COLD state.
2-3 PERIODIC MAINTENANCE
● If the clearance is out of specification, first remove the
cam chain tensioner, camshaft housing, camshaft.
To install the tappet shim at original position, record
the shim NO. and clearance to present by“ A”,“ B”,
“C”,“ D”mark on the cylinder head.
Select the tappet that agree with tappet clearance
(vertical line) and shim NO.(horizontal line) as refer to the
tappet shim selection chart. (Refer to page 8-29∙30)
Adjust valve timing, install the camshaft housing and
the tensioner.
After the crankshaft rotate about 10 times, measure
the valve clearance.
If the clearance be not agree, adjust the standard
clearance as the same manner above.
● In case that valve adjustment which there is no
the tappet shim selection chart, please follow instructions
of example in the below.
For example, the intake clearance is 0.4 and the shim
is 170 (1.70 mm), select 195 (1.95 mm) of the shim
which 170 (1.70 mm) of the shim add up the excess
clearance 0.25 mm when adjust with the standard
0.15 as the intake standard clearance 0.1��0.2 mm.
the actual file has pictures .
jongs
    • http://www.myspace.com/jongs420
« Reply #18 on: May 14, 2007, 05:49:11 PM »
you take screen shots by pressing the "print screen" button on the keyboard and then paste'ing it into paint, then save and post on photobucket blah blah blah.
jongs
seanuk
« Reply #19 on: May 14, 2007, 06:46:28 PM »
Yep, thats the same maintenance / workshop files I have, and got for FREE
