  • January 19, 2019, 11:17:50 AM
Pages: 1 2 [3] 4 5 6
Author Topic: valve clearance question  (Read 37604 times)
Mike on the Rock
    • www.seaies.com
Re: valve clearance question
« Reply #20 on: December 23, 2009, 12:28:03 AM »
Shims are available in .002 increments.
Looking at my shim collection for the Hyosung Engines, seems that the shims are 0.05mm step difference,
0.05 millimeters = 0.00196850394 inches
Just keep in mind that the Part number is the thickness in mm, not 1000/inches  ::)
Ride safe Mike on the Rock
All my Rides are Naked.
http://seaies.com
Mike on the Rock
    • www.seaies.com
« Reply #21 on: December 23, 2009, 12:53:22 AM »
Yjavascript:Charus(0); >:(you got the tools to measure the diff?
This was meant as a funny
pardon if all didn't get it Wink
You got that correct, just try to get a good set of feeler gauges to measure them is the trick 8)
I have some long bent feeler gauges and a Digital mike to read the shims with.
« Last Edit: December 23, 2009, 12:56:25 AM by Mike on the Rock »
http://seaies.com
Mike on the Rock
    • www.seaies.com
« Reply #22 on: December 23, 2009, 05:26:24 AM »
Got a bent set of feeler gauges
at a surprising price
Read reasonable price Wink
You need at least 3 leaves in the range you you are going to check, so get the one with the most
leaves in the range you need.
Specified clearance is 0.10 - 0.20mm, here in the USA it is hard to get Metric feeler gauges, so you need ones that are marked in both, this gives you strange Metric numbers as the gauges are made in Thousands of an inch thickness.
When checking for ware the clearance gets smaller, when rebuilding can be anything.
for those in the metric world this is nonsense Cheesy
I'm Laughing now  ::) ::) ::) :D
« Last Edit: December 23, 2009, 05:34:01 AM by Mike on the Rock »
http://seaies.com
Mike on the Rock
    • www.seaies.com
« Reply #23 on: December 25, 2009, 04:47:31 PM »
This has 36 leaves:
http://www.sears.com/shc/s/p_10153_12605_00940811000P?mv=rr
Blade Length:   3 in.
Blade Material:   Brass & steel
Blade Width:   1/2 in.
Measures Inch Gaps:   .002 - .035 in.
Measure Method:   Blades
Measurement System:   Inches and Metric
Number Blades Included:   36
Feeler/Gap Gauge Type:   Thickness gauge
http://seaies.com
picoylagniton
« Reply #24 on: February 24, 2010, 06:22:22 PM »
hey guys, anyone can please answer this...what is the factory setting for the valve/cam clearance?
Mike on the Rock
    • www.seaies.com
« Reply #25 on: February 24, 2010, 06:33:40 PM »
Look in the back of the Shop Manual, has the table. ???
« Last Edit: February 24, 2010, 06:35:41 PM by Mike on the Rock »
http://seaies.com
McCool
« Reply #26 on: March 11, 2010, 01:09:33 AM »
I'm really glad I read through this thread.  I think I feel confident enough to check the clearance myself and would probably prefer to have a professional handle the adjustment if it was needed.  Question now would be would Hyosung honor the warranty if I checked the clearances?  I would hope that if I kept a log of oil changes and clearance checks (along with reciepts for parts), that I might have to demonstrate my ability to check clearances, but...
I've seen a couple of ads for schools that teach you how to be a motorcycle mechanic.  That actually sounds like a fun second career!
« Reply #27 on: March 11, 2010, 01:15:10 AM »
No, you can get another mechainic to do it, but unless you're a qualified mechanic they can screw you in the arse
BradCCM
  • Guest
« Reply #28 on: March 11, 2010, 06:00:31 AM »
I would say it matters on what the warranty is for.  If it is found that the valves were not adjusted right, or valve related problem, then you may  have an issue with warranty. If it was a non related problem you would be fine.
hyotouring
« Reply #29 on: March 22, 2010, 09:43:54 PM »
when the cylinder head cover is put back on, should the gasket be replaced?
regardless of whether the gasket is replaced, should threebond be used on the gasket?
thanks!
