  • March 26, 2019, 10:08:51 AM
Pages: 1 [2] 3
Author Topic: Fitting a AIS block off kit on a 06 GT650 with pictures  (Read 17332 times)
bikerpind
  • Svendborg, Denmark
Re: Fitting a AIS block off kit on a 06 GT650 with pictures
« Reply #10 on: August 11, 2011, 04:46:56 PM »
I have noticed that a lot simpler method have been applied to my bike. (2008 650 EFI, but I think this would work on others as well)
The hose that goes from the airfilterbox to the pump have been blocked off by a metal plug which simply stops the pump from delivering any air to the system. I don't know who have done this but it's either the dealer or the guy that installed a Rapidbike kit on the bike.
Eitherway it is worth to consider this solution due to the simpleness of it...
chrissmallwood
« Reply #11 on: August 11, 2011, 06:17:40 PM »
I did this to my bike a few months back and one tip I wanted to add was to check the torque on the block-off plate bolts after a few hundred miles. Mine loosened up after it heat cycled a few times and it developed a small exhaust leak. Once I tightened it back down it has stayed tight.
cruzerjd
« Reply #12 on: August 11, 2011, 10:32:16 PM »
Just finished up, the new gaskets secured the collector so i could get the rest bolted up. Whn i had the LC jet kit, it had  a ball bearingthe blocked the hose between the two pumps. While a simple idea, i wanted to get rid of the clutter.  Will check the torque after a few weeks to make sure it is fine
vogstar
  • Who needs 4 wheels?
« Reply #13 on: August 12, 2011, 12:07:47 AM »
Bikerpind,
I did similar but I just got a piece of tube and joined the two outlets in the airbox with they lead to, havn't had a problem since either.
Sounds awesome on run-off but I have noticed my bike isn't quite as loud under all running conditions
2008 GT650RL Black/Silver
De-restricted, IXIL Oval Shorty, Black hugger, DB Screen, Fender Eliminator, LED Brakelight integrated blinkers, Flushmouts & mirror indicators, R&G Racing crash knobs, Speigler Braided lines, EBC pads, reflective silver rim tap
Snowfox
« Reply #14 on: August 13, 2011, 05:50:53 AM »
I wonder if my mechy would do this. The bike needs to go in for its first oil change and i want him to check out the bikes poor idling performance and all the rusting bolts :/ Try and get it under warranty lol.
SmartGuard Immobiliser.
Kaneg Sliders (nocut).
Spools.
« Reply #15 on: August 13, 2011, 07:16:35 AM »
Try and get what under warrenty?
Snowfox
« Reply #16 on: August 13, 2011, 08:30:41 AM »
The AIS, i told the mechy ive had poor idling and small popping from the exhaust, might have it DCed :/
Spools.
« Reply #17 on: August 13, 2011, 08:35:22 AM »
Can't see them removing original equipment under warranty...
UncleJulian
« Reply #18 on: August 17, 2012, 11:04:15 PM »
I'm about to go from stock exhaust to a straight through and I'm thinking I will have a lot of decel popping, is this AIS block-off thing supposed to reduce air going into the engine during deceleration so less popping or something?  Also, mine is a 2011 gt650r, and I don't know if the computer adjusts for this after riding around a bit.
Hyo650R
« Reply #19 on: November 13, 2013, 12:44:26 PM »
Great post very helpful..... Just a note for the 2008 GT650R comet we only have one AIS spent the better part of 10 minutes looking for the rear one that wasn't there haha!   ;D
Pages: 1 [2] 3
