  • February 17, 2019, 07:06:12 PM
Pages: 1 2 3 [4] 5 6 ... 8
Author Topic: GT650R 2011  (Read 10434 times)
MaxBiker
Re: GT650R 2011
« Reply #30 on: September 01, 2012, 01:08:04 PM »
leeway is a tolerance. like saying your not required to have it spot on because you have a tolerance of + or - 10%.
Quick question, how many Km's did you have on those old tires? and how did you get it down to the wire in just that thin line? burnouts?
2011 Hyosung GT650R EFI (8 Ball Black)
Dyrt_shadow
Re: GT650R 2011
« Reply #31 on: September 02, 2012, 10:27:24 PM »
tks maxbiker.
the old tyres made 9900kms, and no no burnouts at all, yes it looks like but no.
Snowfox
Re: Re: Re: GT650R 2011
« Reply #32 on: September 03, 2012, 01:33:28 AM »
tks maxbiker.
Sounds abou right, my stockers made 10kkm before going to canvass.
SmartGuard Immobiliser.
Kaneg Sliders (nocut).
Spools.
MaxBiker
Re: GT650R 2011
« Reply #33 on: September 03, 2012, 03:21:38 AM »
what the hell kind of tires are you running? I'm at almost 18,000 and I still have enough tread to go a few more. Are you guys redlining everywhere you go?
Snowfox
Re: GT650R 2011
« Reply #34 on: September 03, 2012, 04:44:48 AM »
redlining has nothing to do with tyre tread  ???
I use mine everyday, 60Km to work and back + weekend rides for Novice Riders.
Spools.
MaxBiker
Re: GT650R 2011
« Reply #35 on: September 03, 2012, 08:06:40 AM »
Yea, I use mine everyday to work and back, 140 kms per day, 5 days a week in every type of weather you can imagine. That doesn't have anything to do with tread either. I say redline because that will put more stress on the tire causing it to wear faster.
Dyrt_shadow
Re: GT650R 2011
« Reply #36 on: September 03, 2012, 06:29:19 PM »
yep just like me. the only thing that im thinking of is pressures.
max what pressures do you have?
MaxBiker
Re: GT650R 2011
« Reply #37 on: September 10, 2012, 02:42:07 AM »
My rear tire is sitting at 33 PSI
Carbon Rod
  • Guest
Re: GT650R 2011
« Reply #38 on: September 10, 2012, 05:05:30 AM »
pah, wrong... if you are dropping the clutch and accelerating fast it will put stress on the tyres, corners will do it too, also riding really fast 150kmph+ (drag from wind being the main cause)... simply red lining it will not put any extra stress on the tyres.. simple physics?
pretty sure in Australia it is spelt 'tyres'?
MaxBiker
Re: GT650R 2011
« Reply #39 on: September 10, 2012, 03:47:11 PM »
pretty sure i don't care how things are spelled in Australia, I spell things the correct way. look it up in the dictionary and tell me if you find "Tyre" with the definition of "rubber around a rim" then look up "tire". and before you even say it, Yes, Tire can also mean: "I tire of this conversation". words can be spelled the same and have different meanings.
