  • June 24, 2019, 09:58:03 AM
Author Topic: Rear wheel hub  (Read 1943 times)
Delarium
Rear wheel hub
« on: January 30, 2013, 09:27:35 AM »
Hi from Sweden :)
I have a Hyosung TE450 Rapier (swedish name anyway), and I need a new rear wheel hub. Do you know where to buy these? Is it the same as on the Suzuki LT (Z) 400?
Mine is 4x110mm, 20 splines i think. The LTZ is not so expensive, but the Hyosung is...
If you have any advice where to buy these at resonable price, I would be very glad for that information.
BR
Jamesballie
Re: Rear wheel hub
« Reply #1 on: February 02, 2013, 05:18:41 AM »
They should be the same part. Good chance anyway, the frames are identical. Just pull up the oem parts list on both and you should be able to tell if it will work.
michaelbell85
Re: Rear wheel hub
« Reply #2 on: February 07, 2013, 08:34:49 AM »
did you find out if the ltz parts worked or not
Delarium
Re: Rear wheel hub
« Reply #3 on: February 17, 2013, 08:51:51 PM »
I don't know, not sure if I want to order this part if not be 100% sure it will fit. Anyone else know if it will fit?
Delarium
Re: Rear wheel hub
« Reply #4 on: February 19, 2013, 02:48:35 PM »
Anyone, please? Does the wheel hub from LTZ400, DVX400 or other fit the Hyosung TE450 ?
