  • September 21, 2020, 04:57:25 AM
Author Topic: Vacuum and fuel line routing????  (Read 7915 times)
Re: Vacuum and fuel line routing????
« Reply #10 on: January 31, 2014, 12:52:12 AM »
Do you have the item to which you've marked D and E up on?
If so, would you mind posting a picture as to how that bolts on your tank? As I don't have that part. I'll look and my bike and mark those up tomorrow.
« Reply #11 on: February 01, 2014, 03:48:11 AM »
Okay.
So its technically Saturday, first whoops.
Second whoops, it was like 1am when I recorded this so its dark and the exposure was wrong on the drift and a;sdlfkjasldkfja;sdlkfjasdlkfjasdf
I hate this video with a passion. Everything is wrong in terms of what I usually consider watch-able.
Hopefully it helps. In regards to carb pipes, you have two drain pipes on the left hand side underneath the bowl drain screws, the input in the top and on the right hand side you have an overflow/breather pipe that is connected to both carbs. IF you need more information on what that looks like (if the pipes aren't on it) lemme know and I'll take some pictures for you.
Anyway, onto this POS.
Stoo2k
« Reply #12 on: February 01, 2014, 10:05:33 AM »
I have just added the picture of the fuel tank petcock.
Thank you for the video. I should be able to get somewhere with that.
Great help indeed.
« Reply #13 on: February 01, 2014, 01:45:55 PM »
Referring to my video, the second port on the rear rubber boot that I talk about going into the petcock, that will use a pipe to go from there into J, I is a pipe from there to your vacuum fuel pump,  K is a breather/overflow pipe.
Stoo2k
« Reply #14 on: February 02, 2014, 05:18:27 PM »
Can the helpful amongst you check this diagram and make sure its right please.
With the help of everyone and from what I think should be logically right from hose lengths and diameters here is what I have concluded.
Is this correct??
« Reply #15 on: February 02, 2014, 10:04:36 PM »
Looks correct here.
Give 'er a crank.
Stoo2k
« Reply #16 on: February 03, 2014, 12:25:41 AM »
I did. Nothing!!!!
I'm getting annoyed now. What can I check it what are the steps I should be taking now?
« Reply #17 on: February 03, 2014, 09:52:58 AM »
How long did you crank it for?
Due to the nature of everything being vacuum, you'll have to either crank for a while or manually fill the carbs with petrol before you have a go, it has to suck the petcock open to allow fuel into the fuel pump then open the fuel pump to pump it into the carbs to then fill both float bowls. If you want to make sure its all working properly, just pull off the carbs fuel pipe (the pipe that the carb receives fuel from) and just crank a bit. If fuel comes out, you know that you have to continue cranking. May also be worth checking for spark as well if you do.
Stoo2k
« Reply #18 on: February 03, 2014, 11:09:01 AM »
I will try that a bit later. Thanks for the help so far.
