  • July 16, 2018, 11:30:50 AM
Pages: 1 2 [3]
Author Topic: 2013 GT250R EFI Is sputtering at low rev range when hot  (Read 4492 times)
dextrous
Re: 2013 GT250R EFI Is sputtering at low rev range when hot
« Reply #20 on: April 01, 2015, 05:03:15 AM »
TPS output is 3.88 while key is turned to ON position, engine off (not running, throttle closed).
Seems way too high...
Should I just change TPS?
« Last Edit: April 01, 2015, 07:35:49 AM by dextrous »
600sfx
« Reply #21 on: April 01, 2015, 06:56:44 PM »
If that reading is correct, then something is wrong with your TPS.
2008 GT650R EFI
dextrous
« Reply #22 on: April 29, 2015, 09:12:48 AM »
FINALLY fixed my bike. TUrns out it was a burnt out lead plug (Rear). on visual inspection there was an obvious burn mark on the outside of it (where it plugs into the spark plug).
$20 fix.
Hyosung GT250R
« Reply #23 on: August 26, 2017, 06:37:13 AM »
Did anyone else fix it with a faulty cable or they found its something else?
Pages: 1 2 [3]
