  • January 19, 2019, 04:08:52 PM
Author Topic: gt125r carburetors  (Read 1236 times)
dr_jekyll
gt125r carburetors
« on: March 25, 2015, 11:22:13 PM »
I guys .  the carbs on my gt125r are totally goosed an im looking for replacements.
unfortunately ive been unable to source any, can anybody recommend where I would be able to get a pair or alternatively are there any other engines I could use the carbs from that will be a direct fit?
many thanks
Re: gt125r carburetors
« Reply #1 on: March 26, 2015, 12:25:35 AM »
I've not been able to find any reasonably priced ones for over a year.
« Reply #2 on: March 26, 2015, 12:44:10 AM »
FWIW the carbs are the same as on a Yamaha SRV250 Renaissa, and also a Sachs Roadster (has Yamaha engine) as long as it's the twin-carb version - both far rarer machines than the Hyosung GTR.
« Reply #3 on: March 26, 2015, 05:31:21 AM »
....the carbs on my gt125r are totally goosed ....
What exactly on your carbs is goosed?
There are only a couple of parts that need maintenance. Items like jets, o-rings, the floats, the needle and seat are freely available as spares. The main carb body can be cleaned easily enough once removed from the bike and disassembled.
Have a "gander" ;) here http://www.hyosungpartsonline.com.au/
The carbs on 125 and 250 are 'Makuni BDS26 TYPE(DOUBLE)'. Makuni no longer make the BDS series but there are equivalent Makuni replacements.
Try a local Makuni carb distributor near you http://www.mikunipower.com/Distributors01.htm
Watch this strip down of a Makuni carb on a Yamaha Virago 250 for how to strip down and clean your Makuni carbs.
https://www.youtube.com/embed/neaBAYm8iss
« Last Edit: March 26, 2015, 05:33:08 AM by Hylife »
« Reply #4 on: March 27, 2015, 12:26:53 PM »
ミクニ BDS26-ダブル キャブレタ
Sparkz
« Reply #5 on: March 27, 2015, 10:18:39 PM »
Having a similar problem. I have GT125/R conversion which has had larger main jets put in and air box adapted to accommodate. Trouble I'm having is that front carb is not getting any fuel. Previous owner cleaned carbs but with gaskets and o-rings still in. Where can I get carb rebuild kits or even replacement carbs? I've heard Mikuni don't make the BDS26 anymore. Also... Anybody know of a K&N lunchbox filter that will fit? Still think it's not getting enough air. Thank you
