  • July 16, 2018, 11:25:28 AM
Pages: 1 2 3 [4]
Author Topic: neutral light won't come on  (Read 4061 times)
Christmas
Re: neutral light won't come on
« Reply #30 on: August 18, 2017, 01:27:50 PM »
Maybe temp is reading higher because the bike is running properly?
I dont know how much poor running would affect the temp though.. but before I fixed my intake leak mine was running hot and once i taped it up it ran cooler and then once i replaced the boot entirely it ran much cooler..
Could it work in reverse? Poor running = less heat?
jose costa
« Reply #31 on: August 19, 2017, 03:44:28 AM »
good evening. I undid the extra ground, reconnected the rectifier to the wiring harness connector and kept a positive and negative lead for the battery. The voltage in post-key voltmeter increased, as it had not been for a long time. But I still think there is a failure in temperature indication ... today I identified a problem in the SAV valve, cracked housing and variations in amperage that reached 2.0amp when hot. And should not be more than 0.6amp. I blocked the AIS and I will test with and without load on the SAV connector (I installed lamp on the SAV connector to simulate a 0.54 / 0.6amp load)
jose costa
« Reply #32 on: August 19, 2017, 03:48:11 AM »
It's the neutral bulb that went back on its own, and stopped working after I switched off the SAV ...
Pages: 1 2 3 [4]
