  • March 24, 2019, 12:08:00 PM
Author Topic: dealer mode on 2013 gt250r?  (Read 3474 times)
r052tg
« on: June 01, 2015, 02:27:31 PM »
Hi everyone ,do you guys know how to make the dealer mode on 2013 gt250r?
2008 can connect two wire together and get into dealer mode .
I try that on a 2013 ,but it didnt work...
Thank you ;)
agpcardoso
Re: dealer mode on 2013 gt250r?
« Reply #1 on: June 03, 2015, 07:38:15 PM »
To confirm the memorized malfunction code :
Turn the ignition switch alternately, “ON” and “OFF” position, for 2 seconds by three times.
BE CAREFUL
If the ignition switch is turned alternately, “ON” and “OFF” position, for 2 seconds by five times, the ECU is initialized.
See error codes
« Last Edit: June 03, 2015, 07:59:31 PM by agpcardoso »
r052tg
« Reply #2 on: June 06, 2015, 11:05:33 AM »
do you have the new service manual for 2013 efi?
Thank you
Chill
« Reply #3 on: June 13, 2015, 04:17:49 AM »
Hi r052tg
Short answer is.
Step 1: short across the dealer plug.
Step 2: turn on ignition but don't start the engine.
Step 3: hold down the select button on your dash.
Error code will appear in your clock space if done correctly.
Same process on all hyos with a delphi ecu.
Sent from the Bowles of hell with my wejiboard
dextrous
« Reply #4 on: June 17, 2015, 04:29:25 AM »
yeah, u just gotta hold select, for a long time, even after it flashes the clock.
To short the pins is easy, take off back seat, use a paper clip (or any bit of wire) and bend it into a U shape and find the loose plug and short the 2 connectors
Boostinu13
« Reply #5 on: January 12, 2018, 06:04:41 AM »
Hello, was searching and found this forum.  I know it is abit old but thought better than starting a new thread.
I have a 2011 gt250r.  FI light comes on as soon as you as you turn the ignition on. You here the fuel pump work fine, it starts (sometimes takes abit of turning over sometimes straight away) and then goes fine.  It did turn off when I went into N today but started right away and no problems before or since.
I have tried all these methods to get the error code with no luck.  If I hold select down it just does my clock even for over 15 seconds, key on and off nothing.
Any help would be great to get the error code would be great.
Thank you
« Last Edit: January 12, 2018, 06:38:14 AM by Boostinu13 »
