  • May 22, 2019, 06:02:58 AM
Author Topic: 2012 gv650 pro, not running well.  (Read 3175 times)
blues
Re: 2012 gv650 pro, not running well.
« Reply #10 on: July 16, 2015, 03:56:32 AM »
Yes it did but don't forget to put a fusable link in.
« Reply #11 on: July 16, 2015, 03:05:27 PM »
...but don't forget to put a fusable link in.
Better than a fuse is a "self healing circuit breaker". Never need to replace a fuse again. When the fault goes away the circuit is made whole again. If in Oz $8 from Jaycar or $12 from Supercheap auto
http://www.jaycar.com.au/Passive-Components/Circuit-Protection/Circuit-Breakers/Chassis-Mount-Autoreset-Circuit-Breaker-30A-12VDC/p/SF4102
http://www.supercheapauto.com.au/online-store/products/SCA-Automotive-Circuit-Breaker-30-Amp-Automatic-Reset.aspx?pid=120462#Recommendations
blues
« Reply #12 on: July 18, 2015, 03:35:43 AM »
 Great idea...
I also found a dramatic increase in performance as well as fixing the very annoying neutral indicator which never went off.
So happy days!
blues
« Reply #13 on: September 11, 2018, 12:15:02 PM »
Hi guys, sorry for not getting back to you all and thanks again for everyone's input to the problem I was experiencing but the problem was solved by replacing the spark plug caps, one had a hairline crack. since the replacement the bike has not missed a beat and runs like a dream...hope this helps others out 8)
« Reply #14 on: September 17, 2018, 09:18:28 AM »
Sheesh!
3 Years.
What'd you go inside for?  ;D
blues
« Reply #15 on: October 01, 2018, 07:00:59 AM »
HaHa Yeah Hylife it has been a while I know, but at least I came back and reported what fixed the problem. I've had 3 years of working 7 long days and sleeping 7 short nights but I have a new job and a life again! Still riding my beloved 650 which is still going strong.
« Reply #16 on: October 01, 2018, 09:24:38 AM »
Speaking from an auto sparkies point of view , the "self healing" breaker is a very bad idea .
Why would you want to close up continuously (after it cools down) on a fault ?
Stick to fuses and when they blow , find out why and fix the fault because fuses seldom blow for no reason .
Using fuses will also save burning your machine to the ground ( correctly rated fuses that is  ;) ) .
There is a reason fuses are STILL used in today's automotive , microprocessor controlled machines  .
« Last Edit: October 01, 2018, 09:33:19 AM by spit051261 »
blues
« Reply #17 on: October 01, 2018, 01:21:12 PM »
I agree, that's why I stuck with the old glass fuse  ;)
