  • July 19, 2018, 02:10:46 PM
Pages: 1 [2] 3
Author Topic: Trailtech Vapor and Indicator Dash Install  (Read 2178 times)
Re: Trailtech Vapor and Indicator Dash Install
« Reply #10 on: March 06, 2016, 10:02:31 PM »
What happens if you just plug the stock speedo signal into the dash?
The stock waveform will be a LOT higher resolution than what that kit provides.
kennylxix
« Reply #11 on: March 06, 2016, 10:13:07 PM »
I'm not sure. I'd assume at best it would read way high as the stock on has multiple pulses per revolution.
The speedo seems very responsive.  At 30mph the magnet is going past the pickup about 7 times a second so it should be sufficient.
Sent from my butt using Tapatalk
« Reply #12 on: March 06, 2016, 10:25:45 PM »
Can the dash not be tuned in this regard?
How is the dash adjusted for different outside tyre diameters?
kennylxix
« Reply #13 on: March 06, 2016, 11:20:35 PM »
It is adjustable by mm increments for tire circumference but since its designed to be used with the included sensor its not adjustable for pulses per revolution. Although I suppose, depending on how many pulses the stock one put out, the size could be fudged to trick it.  I'm not sure how low the adjustment can go. But that is a possibility
« Reply #14 on: March 07, 2016, 03:37:27 AM »
"I swear Mr Dashboard, you are installed on a Go-Kart! ..you look quite the piece as well!"
kennylxix
« Reply #15 on: March 07, 2016, 05:33:18 AM »
Exactly. Man now you have me thinking. Ill have to put that stock sensor on my scope and see what its up to.
kennylxix
« Reply #16 on: March 07, 2016, 05:34:32 AM »
So the only real issue I have with the whole setup is the indicator lights are pretty much impossible to see in sunlight. I think some LEDs will be in order.
kennylxix
« Reply #17 on: March 07, 2016, 01:43:22 PM »
I didn't realize the kit came with led bulbs. I replaced the incandescent with the LEDs and now I can see them in the daytime!
I'm not sure why they bother with the incandescents.  I guess if the circuit the are in has no other resistor the led could get overpowered. Not an issue with mine.
humanballistics
« Reply #18 on: March 08, 2016, 10:28:17 PM »
This all looks like a cracking fun mod. I'm enjoying watching :)
06 GT250
spaz666
« Reply #19 on: March 19, 2016, 03:04:24 PM »
Ok here are few pics:
Turn signal on:
Rotor bolt:
Adhesive backed speed sensor:
Temp Sending Unit:
Bottom of Bracket showing required trimming for wire clearance:
View from the top (still need to loom some wiring)
Backlight on:
Does the backlight stay on for night riding?
Sent from my HTC_PN071 using Tapatalk
Pages: 1 [2] 3
