  • June 24, 2018, 02:23:30 AM
Pages: 1 2 3 [4] 5
Author Topic: 350 cc big bore conversion  (Read 5305 times)
Dagra82
Re: 350 cc big bore conversion
« Reply #30 on: March 14, 2017, 06:38:47 PM »
I already have the cylinders rectified. I have attached the segments to the pistons
Now I'm looking for better quality bearings than the ones on this motorcycle
« Reply #31 on: March 27, 2017, 09:56:28 PM »
so this is the 350.. kit in the picture?
Dagra82
« Reply #32 on: April 03, 2017, 07:13:13 AM »
I am trying to attach a 58.5 mm diameter piston to the hyosung cylinders.
It's a test . These pistons have less skirt, more cooling holes.
85fordyota
« Reply #33 on: April 25, 2017, 07:25:56 AM »
I like the increased displacement.  But for me I'm more interested in the unrichened fuel setup. Could you kinda give a break down on that? Thanks..
Dagra82
« Reply #34 on: April 30, 2017, 05:41:31 PM »
The original piston of the hyosung has a compression of 22.5 mm and the new piston has a compression of 20 mm.
In order to increase the compression I have removed the gasket from the cylinder and of three I have left a cylinder head gasket.
I already have half engine mounted and for now it looks good.
subefotos
When I have the engine mounted I will do a good run in the engine.
When I finish the writing, I will take it to a professional in Valencia (Spain). When I know the modified gum and the higher or lower needles I will indormare.
« Reply #35 on: April 30, 2017, 09:08:42 PM »
If you removed the head gasket completely, this is not good, right?
I know it's an oil cooled engine, so no water to worry about, but still, there will be oil passing through between the block and the head.
« Reply #36 on: May 02, 2017, 09:08:05 AM »
Loving the pics!
I was thinking the same. From my understanding, the head gasket has been kept but not the base gasket (but he said of the three?). Maybe used a smear of goopy stuff?
It must be a safe place judging from the bars on the inside of the windows  ;D
« Last Edit: May 02, 2017, 09:11:01 AM by Joss »
Dagra82
« Reply #37 on: May 04, 2017, 04:06:07 PM »
In the cylinder with the carter I have put silver Nural silicone gasket. In the cylinder head, I have placed only one metal joint of o, 25 mm.
I will try to take more photos
masush
« Reply #38 on: June 13, 2017, 08:06:41 PM »
Geniuse Guy..
Unbelieable..
may be if you create a video. or know a video. It would be awesome.. It would be helpful for alots of people
golgo-13
« Reply #39 on: July 04, 2017, 08:42:46 PM »
This is awesome work.  You should buy up some CBR pistons from ebay, machine them to the same specs, and sell Bore up kits to us peasants!
Pages: 1 2 3 [4] 5
