  • May 25, 2018, 07:23:33 PM
Author Topic: ARGGHHHH  (Read 645 times)
Snail_94
ARGGHHHH
« on: January 20, 2017, 10:46:15 PM »
✨✨HELP!✨✨
Right last night going down gears to a stop my bike decided to cut out ( electrics still worked fine )
I managed to get it started again after a few minutes.
NOW. approaching a roundabout bike dicided to do the same but this time won't fire up , I've I get lucky it may fire up and stay on BUT the second I use the throttle it will cut out and die again. ( The electronics DO work still)
THIS IS ON A GT125R 2007 ( CARBD)
Suggestions please !
P.s bikes not with me atm so anything I am advised I will try tomorrow ,
Thank you in advance
Re: ARGGHHHH
« Reply #1 on: January 22, 2017, 08:26:33 PM »
When I first started reading it, it seemed a classic case of the side stand switch but then you mention the throttle and now I'm going with coils/carbs.
First check the SSS
Second check your coils resistance and your battery voltage
Third start giving your carbs and choke a service.
Re: ARGGHHHH
« Reply #2 on: January 24, 2017, 05:04:18 PM »
Noticed a lot of people on facebook telling you to adjust your mixture screws, please don't.
Check to make sure your pump is providing fuel to the carbs, and that there is fuel in the bowls.
Very little fuel would allow it to run at idle but nothing else.
Let us know what you find.
Re: ARGGHHHH
« Reply #3 on: January 28, 2017, 09:23:56 AM »
Put battery on a charger overnight.
Put in some carby/fuel injector cleaner in a full tank of new fuel at twice the car rate.
Snail_94
Re: ARGGHHHH
« Reply #4 on: February 01, 2017, 12:44:54 PM »
Hello carbs have been taken apart and cleaned and put back together and nothing 😫
Sorry about the late reply
Snail_94
Re: ARGGHHHH
« Reply #5 on: February 01, 2017, 12:45:35 PM »
And ninja who ever you are on book I haven't adjusted it :(
Snail_94
Re: ARGGHHHH
« Reply #6 on: February 01, 2017, 12:46:06 PM »
Fuel taps been changed as well now
Snail_94
Re: ARGGHHHH
« Reply #7 on: February 01, 2017, 12:46:58 PM »
Re: ARGGHHHH
« Reply #8 on: February 01, 2017, 01:36:15 PM »
https://goo.gl/photos/6syW8s6ZRNYr1BxLA
That battery is goosed. Your clocks are going off when you crank it!
