  • March 24, 2019, 08:42:31 AM
Author Topic: known hyosung part numbers that fischer used  (Read 730 times)
mad8vskillz
    • the only source on the internet for fischer mrx parts
« on: March 22, 2017, 03:30:14 PM »
not a complete list, but what I *know* so far
64741HM8100   Rear Axle Spacer (right)
09159H16002   Rear Axle Nut
54711HG5101   Front Axle
54731HM8100   front wheel bearing spacer
56271HF4501PLA   Bar end
35950-30A04   yellow rectangular reflector
25520-32C00   shift linkage
57110HG5803   right grip and throttle tube
33500HN9100   spark plug cap boot
32900HN9111   cdi ignitor
15100HG5100   Fuel vacuum pump
13200HN9100   carburator assembly complete
56501HP9260   mirror set
33430HN9100   Coilpack short rear
33410HN9100   Coilpack long front
58410HN9103   choke cable
58300HN9104   throttle cable
57211HG5800   left grip
   shift linkage rod 193mm
57661HJ8200   clutch perch cover
   shift linkage boot
37000HM8130   key set
54721HM8100   front axle nut
64731HM8100   rear wheel bearing spacer
58600HP9201   throttle return cable
32910HN9101   pulse control unit
32800HN9101   regulator rectifier
36610HN9151   wiring harness
37840HN9102   kickstand switch
38500HM8110   horn
38610HL7300   Hazard Relay
17860HN9100   Radiator Thermostat Temperature Switch
17720HN9100   Radiator Cap
36740-35c00   fusebox
38740HM5401   fuel pump relay  5n22
37740HN9100   rear brake light switch
33840HM8101   positive battery lead
31800HG5100   Starter relay
37200HP9200   right control pod on off hazard starter switch
37400HN9100   left side control pod lights and choke
17800HN9102   radiator fan
17710HN9102121   radiator
69609HN9100   Rear master cylinder with cup
69211HM8101   rear disk rotor
64511HN9101   44t rear sprocket 525 pitch
69300HP9500   rear brake caliper
59221HM8160   right front disk rotor
59211HM8101   front left rotor disk
59400HP9500   Right front caliper
59300HP9500   left front caliper
www.mad8v.com - the only place with new fischer mrx parts!
