  • February 18, 2018, 11:55:13 AM
Author Topic: No spark on sparkplugs???  (Read 807 times)
Re: No spark on sparkplugs???
« Reply #10 on: April 10, 2017, 12:17:41 PM »
Find out what that CHe error code is.
In the rear of the bike, there is a loose two pin connector. Put a paperclip in it so that you bridge the pins. You should get a cXX code. XX is a number. That number will give you a clue as to what the problem is. I suggest that it's probably a vacuum leak, or a sensor not plugged in.
« Reply #11 on: April 12, 2017, 02:05:01 PM »
Sounds like only running on one cylinder/lack of power.
Check the temperature of the exhaust pipes. Is one colder than the other?
PeterNOR
« Reply #12 on: April 12, 2017, 03:23:19 PM »
I can try to check the tempratures of the exhaust pipes. Not sure if its running on both. And when i check for the error codes its not showing because the FI lamp must be on i think. I can try and see if i can reed out some error codes.
I think maybe there is something wrong with the relationship between air and fuel the engine gets. I tried to hold my hand in front of the air filter to see if it took in too much air but the bike was still running bad so maybe it takes in too much fuel?
