  • April 23, 2018, 08:41:43 AM
Author Topic: GV650 Trouble Starting  (Read 366 times)
Azlani
« on: April 11, 2017, 07:33:14 PM »
Hello, SO I changed the spark plug and the gas tank is filled but I have not been able to start the Bike. I did not start it all winter but when I tried a few weeks ago it turn on but then immediately dies. I put in a new battery a year ago and last fall it started fine with no issues. I also tried to jump start it and it still will not turn on and stay on.
Please help....
What can I do???
Lani
Re: GV650 Trouble Starting
« Reply #1 on: April 11, 2017, 09:21:14 PM »
What happens when you try and start the bike. What sounds do you hear? What lights can you see? Do the lights die if you press the start button?
« Reply #2 on: April 12, 2017, 10:55:12 AM »
I store mine all winter in my garage, with a full tank of gas (to stop condensation/rust in the tank), and use a battery conditioner/charger occasionally to try to keep the battery right, and it starts again in the Spring OK.
The battery has to be 100% and the old gas may have deteriorated - I add a good dose of injector cleaner to the first few tanksful and that seems to even up any rough tickover......
I hope you get it sorted out.
« Reply #3 on: April 12, 2017, 02:10:12 PM »
... I put in a new battery a year ago and last fall it started fine with no issues. ....
Lani
How long has it been since the engine started and you went for a ride?
A year old battery can still die prematurely if not used regularly.
Put battery on external smart charger at no more than 4 amp rate overnight.
« Reply #4 on: April 12, 2017, 07:48:07 PM »
My guess is that your Carb is gummed up.
To start it on its own you will need a good battery. But if you gave it a jump it would start(if it could) regardless of the condition of the battery.
