  • June 01, 2020, 08:18:18 PM
Author Topic: Rally SF50 - Can't stay Started  (Read 2903 times)
greenline4
« on: May 18, 2017, 02:43:31 AM »
Hi to ALl
Hope you're doing well. I bought a 2005 Hyosung SF50 and When i start it with the Crink ( not the starter button). the engine stays started during 2  to 5 minutes and it stops. and when i start the engine again, it stays started less than 2 minutes etc.
ANy suggestions please ? The gaz and Oil are fully loaded.
Thank You
Re: Rally SF50 - Can't stay Started
« Reply #1 on: May 18, 2017, 10:26:43 PM »
Have you checked the spark plug for fouling?
greenline4
« Reply #2 on: May 23, 2017, 02:50:51 AM »
Yes i DID. I even change it for another used one .
« Reply #3 on: May 24, 2017, 09:42:12 PM »
Does it die out faster if you hold it at higher revs?
greenline4
« Reply #4 on: May 26, 2017, 01:40:24 AM »
Sorry but what do you mean by hold it at higher revs ? didn't understand, i m really a beginner on this world... Thanks
« Reply #5 on: May 26, 2017, 07:24:26 PM »
That's alright =D I'm not being hugely helpful, I'm just trying to diagnose. It's been a while since I've had a two-stroke machine.
I'm trying to work out if your problems are related to heat, or to fuel. It might be that the float levels in the carb are set too low, and it's drinking fuel faster than the carb can supply it. Or it could be an electrical component getting hot, and creating resistance enough to stop the spark.
Have you tried running it with the petrol tank cap off? If it still dies out with the cap off, we can at least rule out vacuum effect in the fuel tank.
greenline4
« Reply #6 on: May 29, 2017, 07:30:22 AM »
I WILL TRY TO REMOVE THE gaz tANK AND TEST. i WILL GET BACK TO YOU SOON.
i REALLY APPRECIATE YOUR HELP
greenline4
« Reply #7 on: June 17, 2017, 11:47:41 PM »
Thanks. I didn't ty this yet because of the bad weather.
But i have another symptoms that could maybe help you to understand more what's going on.
whan i start the engine. it stays started with a noise like the engine wants to stop ( low level or whatever...). and as soon as I touch the speed-up to move, the engine stops immediatly. what do you think ?
greenline4
« Reply #8 on: June 18, 2017, 06:43:07 PM »
Hi
I did the test you told. Same result. What do you think ? It might be the gas filter or carburetor ?
Please let me know
« Reply #9 on: August 13, 2017, 08:19:03 PM »
Sounds like the carb. Could also be fuel filter.
