  • September 21, 2018, 01:01:10 PM
Author Topic: Duel brake issues/caliper issues  (Read 487 times)
Andygtcomet
« on: July 09, 2017, 01:03:37 PM »
Done a twin disc conversion, custom stainless lines (2 separate), double banjo, new caliper seals (one side), aftermarket master cylinder/levers.
Issue is now I've bled it and back bled it, no air in system, but no pressure on lever, not even trying to move calipers/pistons, just recirculates fluid in reservoir. I did re strip both calipers and found I needed new seals. Once these were in, I had hope, but same issue. The pistons went in quite easy with new seals in but other side was very hard to get pistons in, so wondering if that's the issue or if maybe the master cylinder (new) piston is no good.
All new crush washers were fitted, and system bled and back bled using big syringe, but no pressure and no movement of calipers when operating lever.
Any ideas????
I've ordered another seal kit for other side.
Andy
Bikerjohn90
  • Newbie to Hyosung and loving every second of it
Re: Duel brake issues/caliper issues
« Reply #1 on: August 28, 2017, 07:26:22 PM »
I have nearly the same issue. I fitted new caliper so but now I have no pressure on the leavers at all. Changed front and back  calipers but now no pressure.
Bike + petrol x twisty roads = 😃😃😃😃
Basic maths
« Reply #2 on: August 28, 2017, 07:29:57 PM »
Yeah you can't run two calipers from the master cylinder designed to run only one.
Master cylinder and brake lever from a Bandit 600 is about 9 because there's approximately a quintillion of them for sale in used, new, and aftermarket, they'll bolt right on, and do the bizzle for driving the calipers.
Bikerjohn90
« Reply #3 on: August 28, 2017, 07:37:33 PM »
Ok cool. But the rear isn't doing only thing either so have I done something wrong? I have got all air out the system on the rear but still no pressure
Basic maths
« Reply #4 on: August 28, 2017, 10:16:45 PM »
There's only two choices. Air or leak. Hydraulic pressure is not complex. It's going somewhere.
Have you checked the master cylinder to see if the piston might possibly be jammed? The rear MC is famous for doing that.
