  • April 21, 2018, 03:06:03 AM
Author Topic: Bike dies when i put in gear  (Read 931 times)
Stag
« on: July 27, 2017, 02:40:53 PM »
So i fixed my previous problem with the bike, Now its up and running. The bike starts and revs up just fine. When i put it in to gear, the bike engine dies right away,
IT IS NOT THE KICK STAND SENSOR.
Any ideas on what it could be ?
Dawid_roma
Re: Bike dies when i put in gear
« Reply #1 on: July 27, 2017, 05:45:57 PM »
It will be your side stand sensor just unplug it and it should fix your problem unless there is a problem somewhere in your condition then you have to follow the cable and check if they don't tuck somewhere
« Reply #2 on: July 27, 2017, 08:38:29 PM »
How are you so sure that it's not the side stand sensor, when it so perfectly matches the symptoms?
Have you bypassed the sensor? Unfortunately not's not simply a matter of unplugging it, you do have to bridge the two wires (join them together).
Dojy_biker
« Reply #3 on: July 28, 2017, 01:02:41 AM »
"it's the side stand sensor"
i dissagree, its obviously the entire bike to blame.
See  ;)
********ok thats enough sarcasm*********
******its deffo the side stand switch*******
Ive had one bitch of a day (actually two days) diagnosing and fixing a sick DL1000 (electrical gremlins)
Interestingly it runs the Mitsubishi ECU like my GT650 :)
Wonder if a 1000cc upgrade / transplant could be accomplished...
« Reply #4 on: July 28, 2017, 01:48:36 AM »
dojy,
Do it. Do it now.
...why are you still reading?? GO!
Stag
« Reply #5 on: July 29, 2017, 12:55:29 AM »
IT IS NOT THE ****ING KICK STAND SENSOR, ITS A BRAND NEW KICK STAND SENSOR, PLEASE NO ONE ELSE MENTION THE ****ING KICK STAND SENSOR, YALL ARE PUSHING ME TO THE EDGE, IT IS NOT THE KICK STAND SENSOR
Stag
« Reply #6 on: July 29, 2017, 12:57:22 AM »
I PROMISE YOU ALL. ITS NOT THE KICK STAND SENSOR. IF IT TURNS OUT IT IS THE KICK STAND SENSOR, I WILL BUY OUT HYOSUNG, ITS NOT THE SENSOR. Please be more constructive
Dojy_biker
« Reply #7 on: July 29, 2017, 04:20:53 AM »
work backwards then.....
sidestand switch relay
diode pack
there is NOTHING else that would cause this. it is sidestand switch related :P (unless your electrics are a complete utter mess and all chewed up)
Christmas
« Reply #8 on: July 29, 2017, 08:50:54 AM »
I don't know what my hyo kick stand sensor connections look like but my old bike had a positive and a negative coming out of it.. did you mix those up? No current flow could potentially read as kick stand down....?
« Reply #9 on: July 29, 2017, 09:47:13 AM »
You're not listening Christmas.
I so wish there really was an edge. On my oath, I would push if I knew I would get away with it ;)
