  • March 23, 2018, 12:16:11 AM
Pages: 1 2 [3]
Author Topic: GV250 bogged down  (Read 1527 times)
Re: GV250 bogged down
« Reply #20 on: September 07, 2017, 01:49:55 PM »
Bogging down will be running on one cylinder. This is a fuelling or spark issue (bad coil?).
Remove tank and agitate vigorously and then drain fuel. Get hold of a button magnet approx. 15mm wide and place on the bottom of the tank at the lowest point. (any loose rust will stick to magnet).
Refill tank with new clean fuel.
Chuck in some injector cleaner (yes it works a treat on carbs) into your tank at twice the rate per litre on the bottle that is recommended for cars.
Go for a good long ride.
Pages: 1 2 [3]
