  • February 24, 2019, 03:00:46 AM
Author Topic: GV/GT 125 carb alignment  (Read 1228 times)
stuartkeith
« on: August 17, 2017, 09:58:15 AM »
Well finally after 3years I have managed to get the Aquilla running. It looks like the issue is due to the way the cable connects to the carbs. when the cable is connected around the arm on the carb and into the slot, the butterflies are half way open not closed!
Is this to do with the cable, or has the bracket been put  on wrong? I did remove it all to clean and free everything, but it was revving before. Also how dose the spring go back on? I had to put back on without spring as it was jamming the rotation of the butterflies.
Re: GV/GT 125 carb alignment
« Reply #1 on: August 18, 2017, 05:15:11 PM »
something to look for. There are 2 slots to put the cable end in on the throttle. you could have it in  the wrong one and it may cause a short cable situation.
look to see if the band clamps are in the way to where the throttle can't retract all the way
I'd check this one first.
stuartkeith
« Reply #2 on: August 21, 2017, 04:33:26 PM »
thanks deffo not the clamps as tried pushing by hand. now after being sat a few days the slides are once again jammed. looks like i need to rub the channels down a little more. looking at pics on google, seems as if i put the white collar on wrong.
Rider97
« Reply #3 on: December 04, 2017, 12:09:26 AM »
Pics please; then I'll know what you're talking about
« Reply #4 on: December 04, 2017, 02:17:26 PM »
there are 2 slots on the throttle cable... you may have put it in the wrong hole. If I'm correct there is only one throttle cable on that bike right?
Rider97
« Reply #5 on: December 04, 2017, 11:04:46 PM »
One cable to the front of the carb (fork side) with the cable cam, and a spring behind it, I also seem to remember a spring in the middle of the two carbs too, but incant remember for sure, will check.
« Reply #6 on: December 04, 2017, 11:19:37 PM »
Perhaps you switched the choke and throttle cable.
choke cable: metal part is straight
throttle cable at the carb:  is curved.
Just a thought.
« Reply #7 on: December 05, 2017, 12:16:58 PM »
Your throttle tube right up on the handle bar has two different positions for the knub thing on the end of the cable to be held in by. If you take the right-hand switchgear box open, you'll see what I mean, although if I've got more time later today I'll get a picture up.
Use the other bit on the throttle tube, put the spring back on the carbs
« Reply #8 on: December 05, 2017, 12:31:36 PM »
stuartkeith
« Reply #9 on: February 08, 2018, 02:15:30 PM »
Thanks, the cable seemed to have shrunk! i removed some of the metal sheiding and all good now, Now however, I cant get the carbs back in with the airbox in place. Ive dropped the engine in the frame by removing the bolts but still seem to be 2-3mm short on space.
