  • June 02, 2020, 01:13:53 PM
Author Topic: [WTA] exhaust leak  (Read 1975 times)
deadstar092
[WTA] exhaust leak
« on: September 01, 2017, 03:47:16 AM »
Greetings KORIDER!
Does it normal to have a hole below the exhaust?
Christmas
Re: [WTA] exhaust leak
« Reply #1 on: September 01, 2017, 07:42:50 AM »
Every motorcycle exhaust I've ever seen has had a small drilled hole within 2 inches of their joints. I don't know why but they're always there. I'm not saying every exhaust will but every one I've seen has.
deadstar092
« Reply #2 on: September 01, 2017, 10:22:32 AM »
i heard the same thing when i ask some of my friends. but just to be sure  ;D ;D ;D
thanks mate.
Christmas
« Reply #3 on: September 01, 2017, 11:35:22 AM »
All good mate
« Reply #4 on: September 01, 2017, 11:55:13 AM »
I've seen ones in strategic places to let water/residue out in the past.
« Reply #5 on: September 01, 2017, 09:41:19 PM »
Complete hear-say:
I've heard it said that it's because of the sulphur used in unleaded fuel as a lubricant. They used to use lead in fuel, but for obvious reasons, they stopped.
Ever notice the rotton egg smell in high powered car exhausts? This is from the sulphur.
Dissolve sulphur into water and you get sulphuric acid.
Burn petrol and you get CO2 and water.
In summary. A hole is drilled to let the sulphuric acid out, so it doesn't eat your exhaust.
pritchardsimon
« Reply #6 on: September 02, 2017, 05:37:56 AM »
Another possibility is if they are purge welding the exhaust, it could be to stop blowing a hole in the weld right at the end when it becomes completely sealed as there needs to be somewhere for the gas to vent. Just a possibility.
Sent from my Pixel XL using Tapatalk
Dojy_biker
« Reply #7 on: September 03, 2017, 10:01:46 PM »
simply just a water / moisture drain point. allows the baffles to drain so they don't retain moisture and prematurely rot the exhaust.
