  • July 16, 2018, 11:25:51 AM
Author Topic: Compression for '04 Alpha 250  (Read 479 times)
smoulding
« on: September 04, 2017, 01:43:26 PM »
I'm getting a reading of 130 to 135psi for both cylinders. The book says it should be around 170, yet a previous post on this forum said 120 or higher is good. I have a carb (non efi) alphasports gv250, 2004. All I did was pull the plugs, put the gauge in there, and turn it over about 5 times or so. The cylinders max out at about 130 to 135psi. Will these readings work? Thanks.
Re: Compression for '04 Alpha 250
« Reply #1 on: September 04, 2017, 09:22:40 PM »
It's a 13 year old bike.. 135psi will do. The alternative is an engine rebuild.
« Reply #2 on: September 05, 2017, 08:23:45 AM »
The actual question is, are you checking the compression because its not running? Agree with umop-ǝpisdn, 135psi for a 13 year old bike is good (unless its mileage is really low).
