  • April 21, 2018, 03:05:03 AM
Author Topic: turn signals wont work  (Read 339 times)
D09hyo
« on: October 26, 2017, 03:13:40 AM »
So i really dont know what else to check. i have stock front turn signals, and led rear  turn signals with resistors. out of the blue, not only are they not working but the green turn signal lights on the display doesnt even light up. usually if a bulb is bad itll blink fast on the display, but nothing is turning on at all. i checked under the seat and the relay is working, i can feel it clicking with each push of the turn signal switch. front bulbs are good, but even if they were bad the display would still function.... right? odd for all 4 to not work. i checked a fuse under rear seat (not sure what that fuse is even for but figured id check it) and fuse is fine. any ideas?
Re: turn signals wont work
« Reply #1 on: October 26, 2017, 10:25:17 AM »
Could be a failed relay.
The clicking just means that the flip-flop inside is working, but the connections internally may be gone.
Get your multimeter out and check that there is power coming on-off-on-off etc from the relay output terminals.
D09hyo
« Reply #2 on: October 27, 2017, 06:44:49 AM »
oh i didnt know that. guess shows how much (or little) i know about relays. ok, i'll check that. thank you!
D09hyo
« Reply #3 on: October 29, 2017, 02:54:18 AM »
dude! thats EXACTLY what it was. thanks a bunch.
