  • February 18, 2018, 11:56:20 AM
Author Topic: Ecu blown 3 times  (Read 413 times)
Tylergage
Ecu blown 3 times
« on: November 11, 2017, 02:51:14 AM »
Heyy guyz i vought a gtr 650 apparntly faulty fuel pump ended up being the ecu now so what i no is the first exu went faulty and they replaced with one which was made in china and the oringal was made in singapore and then the one i boight was made in singapore so im gonna replace the whole wire harness as there probaly a wire shorting out but what qould cause the ecu to blow up all 3 smell like burnt electrics
Sent from my SM-G900I using Tapatalk
vulcan BR
Re: Ecu blown 3 times
« Reply #1 on: November 11, 2017, 01:41:06 PM »
dude, you need to review the main wire! do not try to burn another Ecu before it
check the ECU connector with a multimeter looking for wrong condutivity and voltage.
Tylergage
« Reply #2 on: November 11, 2017, 10:48:30 PM »
Ive put a new wire harness on it gonna check the old one
« Reply #3 on: November 12, 2017, 12:07:39 AM »
Something is definitely not right if your bike ate three ECUs. Agree completely that changing the loom is wise.
Tylergage
« Reply #4 on: November 12, 2017, 09:42:15 AM »
What could i have been looking at on the old wire harness blew a fues my dash also blew idk if anything else did yet
« Reply #5 on: November 12, 2017, 02:17:26 PM »
 just replace it from eBay I bought one for $27 shipped. There is a possibility of your rectifier sending out too much power
UNdocab
« Reply #6 on: November 14, 2017, 02:26:53 PM »
İ ve suspicious with sub harness isolation(short circuit) which has a lot of direct connection to  ecu.
This happen one of my friend once than we found the problem. After making isolation better problem solved
Tylergage
« Reply #7 on: November 14, 2017, 10:03:51 PM »
Ive replaced the whole wiring just because not that good with a volt meter
