  • September 22, 2018, 07:42:09 PM
Author Topic: Inner Clutch cover Gasket Replacement 2015 Model  (Read 306 times)
Hyocentric
  • 2015 GT650R LAMS restricted
  • Trying to keep up with the race!
« on: November 13, 2017, 10:17:21 AM »
Leaking loads of oil from inner Clutch cover Gasket, I have a replacement but have a few questions:
- Does the Outer (circular) Cover need to come off also? Does Rubber ring(seal) need replacing if so?
- Is it as simple as just replacing Gasket or do I have to take off other components such as water pump?
- Also there is a very large nut (Bolt #5 in exploded diagram) below, near the oil level site glass.. what is this? Do I need to do anything with this?
- I am aware I need to also remove oil filter cover for this to come loose, anything else?
- No Torque settings for these bolts? Have seen posts on here stating 6 - 12 Nm (for outer cover) Which is the right torque setting for Inner cover bolts?
I hope to tackle this in next few days, Thanks for your help!
dj.micha1980
Re: Inner Clutch cover Gasket Replacement 2015 Model
« Reply #1 on: November 13, 2017, 04:08:20 PM »
Also doing this in the coming days, replacing the whole cover since i bought a sided bike.
-the cover doesn't have to come off. The o ring should be replaced if you do take it off though
-water pump will come off with cover
-I think that bolt drains the coolant
-Only the top right bolt from the oil filter cover
-torque settings (and most of this info i just gave you) can be found in the manual.
Check https://www.manualslib.com/manual/1177055/Hyosung-Gt-650.html
Good luck and post some pics if you can.  ;)
Hyocentric
« Reply #2 on: November 14, 2017, 01:21:20 AM »
Thanks for your help dj!!! Also for the link!! very helpful but could not find torque setting for bolts....
dj.micha1980
« Reply #3 on: December 20, 2017, 02:03:01 AM »
You're welcome. I guess just tightening the bolts snugly will do. I did loosen them in my 250 and re tighten with no specs and didn't have an issue. Did you finally replace the gasket?
Sent from my SM-T210R using Tapatalk
