  • March 24, 2019, 11:55:03 AM
Author Topic: non starter  (Read 552 times)
tonyleece
non starter
« on: November 16, 2017, 08:30:19 AM »
Hi, i have a gv 250 and around 4 years ago i took the tins off her to airbrush, as i got a bigger bike. well as things go it has taken till now to get her back together and i can pass her onto my son.
I put a brand new battery on, swapped the plugs and put in new oil/oil filter. But she refuses to start, not even an atempt.
Anyone know what might be the problem.
I didn't expect her to start first time, but she worked fine last time she was together.
Any comments welcome, i will make a list and go through it all.
Many thanks for reading this.
Cheers
Tony...
beachpitcrew
Re: non starter
« Reply #1 on: November 16, 2017, 02:49:48 PM »
Simply remember the basics. Air, fuel , and spark. So. Pop a plug wire off and make sure you have spark  if you do. It is no doubt not getting fuel. So shoot a mall amount of starting fluid into the air cleaner and see if it goes. If it runs a few seconds then you know that you need to go through the fuel system. Maybe old nasty fuel.  If it's carb bike they might need cleaned
2011 GV250, 2013 IRON 883
tonyleece
Re: non starter
« Reply #2 on: November 16, 2017, 03:19:56 PM »
Thanks mate i will give that a go 👍👍
Re: non starter
« Reply #3 on: November 16, 2017, 07:55:26 PM »
If you mean it will spin over but not run.... it's your carbs.
there is a love hate relationship I have with the GV carbs.
I have actually done a carb clean by just removing the float bowels.
you will need to remove the side panel coil bracket and you enough access to remove the bowels.
tonyleece
Re: non starter
« Reply #4 on: November 17, 2017, 12:17:28 AM »
Thanks Albert, i will give that a try too.
I have another issue. On the right side of the carby's there is a bkack tube coming from each carby, they join into a single tube, but fir the life of me i cant work out where this tube goes
Re: non starter
« Reply #5 on: November 17, 2017, 03:24:59 AM »
They are drain tubes.  I call them the "Y" tubes.
Ill see if i still have the pics of when i did them.  I had a link before probe in this section but about 6 months ago
tonyleece
Re: non starter
« Reply #6 on: November 17, 2017, 03:28:49 AM »
Do they remain open ended, or are they conected to somthing?
Re: non starter
« Reply #7 on: November 17, 2017, 03:32:45 AM »
Yes. I found the thread. I bumped it up but i didint post pics
« Last Edit: November 17, 2017, 03:34:23 AM by albertinhouston »
tonyleece
Re: non starter
« Reply #8 on: November 17, 2017, 07:38:35 AM »
IT'S Alive!!!!!!!
Thanks so much for the help, my son is very excited now 😎😎😎😎😎
Awesome..
