  • July 17, 2018, 12:38:19 PM
Author Topic: hyosung gv650 aquila gearbox issue  (Read 1063 times)
Adidasandy
« on: December 29, 2017, 10:44:05 AM »
Hey guys, a little advise please. I have a hyosung 2011 gv650 aquila with 25000kms on her. Pulling away up a steep hill from stand still with pillion, got to 7km and it just stopped pulling like I had selected neutral. Pulled over and it doesn't matter what gear I select there is no drive. The further up the gears I go the louder the gearbox gets (rattle noise). Clutch feels as it should and with the clutch pulled in there is no noise. Is this a common issue. Done a search and can't find anything?
Re: hyosung gv650 aquila gearbox issue
« Reply #1 on: December 29, 2017, 10:46:36 AM »
Check your output shaft and front pulley. See if the pulley has been destroyed.
Adidasandy
« Reply #2 on: December 29, 2017, 11:23:22 AM »
Will do, so I need to pull motor out?
« Reply #3 on: December 29, 2017, 01:16:52 PM »
No, take off left rear side cover where drive belt goes.
Download service and parts manuals and things will be much clearer for you.
http://www.hyosung.hu/download/pdf/letoltesek.htm
Adidasandy
« Reply #4 on: December 29, 2017, 11:44:06 PM »
Perfect, thank you. Will start ina few hours with updates.
Adidasandy
« Reply #5 on: December 30, 2017, 03:43:14 AM »
Ok, so the pulley and shaft are destroyed. Is it engine out and split to replace output shaft?
« Reply #6 on: December 30, 2017, 06:42:58 AM »
Only if it actually damaged the shaft.
The pulley is quite soft. What’s the condition of the splines on the output shaft?
Adidasandy
« Reply #7 on: December 30, 2017, 08:25:38 AM »
Theres nothinbg left of both pulley and shaft. New bike in order and this fella can be the donor for the trick bits
« Reply #8 on: December 30, 2017, 09:03:22 AM »
Damn pity.
I was hoping it was just going to be the pulley.
Pity!
Adidasandy
« Reply #9 on: December 30, 2017, 09:26:14 AM »
You and me both :-(
