  • July 17, 2018, 12:37:56 PM
Author Topic: hyosung gv650 aquila gearbox issue  (Read 1062 times)
Re: hyosung gv650 aquila gearbox issue
« Reply #10 on: December 30, 2017, 10:23:32 AM »
FYI, and I know this comes a bit too late, forum member OLEG makes an aftermarket output shaft out of high quality, aircraft grade metal.
https://www.ebay.com/itm/272913385390?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Also, Hyosung revised the front pulley design. Earlier models had a much narrower spline on the pulley. In later versions the spline surface area was widened. I don't know how much that matters in your case, as I am imagining a scenario where the pulley shore between the weight reduction holes.
« Reply #11 on: December 30, 2017, 05:55:19 PM »
Ok. Ghetto albert to the rescue...
There was a guy here in texas the welded the sprocket to the shaft.
 He had just enough teeth to get it in the proper location.  2yrs later still holding up fine.
It was on an st7
I only saybthis because u only have 1 choice right now. If it works great.. If not u didnt lose anything u r still going to have to change. Split the cases.
« Reply #12 on: December 30, 2017, 10:47:19 PM »
I like it!
There really is nothing to lose in giving it a try. Don’t overheat the shaft though.
Adidasandy
« Reply #13 on: December 31, 2017, 05:51:44 AM »
Yeah I was thinking of a tappered shaft and fitting a woodruff key way in and see how long it lasts. And part number 33 was as thin as paper.
« Last Edit: December 31, 2017, 05:55:50 AM by Adidasandy »
« Reply #14 on: December 31, 2017, 10:27:40 AM »
Shaft can be replaced without having to split the crankcase.
All done from the clutch side.
Drain oil first and then lay the bike down on its left side on some big interlocking EVA foam mats.
« Reply #15 on: December 31, 2017, 08:07:44 PM »
Eh?
You sure Hylife? I'm pretty sure the crankcase needs to split. If I am wrong though, I'd love to know how!
Adidasandy
« Reply #16 on: January 01, 2018, 12:38:29 AM »
Would love to know too 100% before I buy the parts. Not doubting you Hylife but a bike mechanic said it's an engine out and split job.
« Last Edit: January 01, 2018, 07:07:10 AM by Adidasandy »
« Reply #17 on: January 01, 2018, 11:20:22 AM »
Woops. Brain fade. Gotta stop surfing the forum when I should be sleeping.
Don't know why but I was thinking of the clutch replacement even though the OP clearly stated the drive shaft.
Sorry, my bad.  :o
Yes, you need to split the crankcase to access the gears, their forks and the drive shaft.
Download these two service manuals as PDFs
this one for the engine
http://www.hyosung.hu/download/pdf/data/service-manual/GV650-carburetor-servicemanual.pdf
and this one for the EFI bits and bobs
http://www.hyosung.hu/download/pdf/data/service-manual/GT650%20EFI%20GV650EFI%20Service%20Manual.pdf
and this one for the parts catalogue which shows good expanded blow-ups
http://www.hyosung.hu/download/pdf/data/alkatresz-katalogusok/GV650FI%20PART%20CATALOGUE.pdf
