  • December 17, 2018, 12:58:00 PM
Author Topic: What oil do you use  (Read 979 times)
Re: What oil do you use
« Reply #10 on: January 09, 2018, 07:25:20 AM »
A bit of fur is normal for older engines/gearboxes . Just normal wear and tear .
Start worrying when you see small or large chunks of solid metal on the plug .
« Last Edit: January 09, 2018, 07:33:27 AM by spit051261 »
« Reply #11 on: January 09, 2018, 07:35:40 AM »
I only change the little o ring. The larger one I never felt the need to bother with.
My sump plug has always had fur on it, which I am presuming belongs to my output shaft bearing
Always?! Right from the start? Can I ask what the odo says? I hv never seen any fur on the plug.Atleast not yet.But am a very sane rider.how long before bearing change do u reckon?
Sent from my SM-G935F using Tapatalk
This may sound stupid but you do have a magnetic sump plug fitted ?
cruiser13
« Reply #12 on: January 09, 2018, 07:36:20 AM »
Lol!! Yes..lol
« Reply #13 on: January 09, 2018, 07:39:42 AM »
Just asking the question ;)
It is quite normal to see small amounts of "metallic fur" on a magnetic sump plug .
How many K's on your bike and how often do you change the oil out of curiosity ?
cruiser13
« Reply #14 on: January 09, 2018, 08:19:50 AM »
Odo says 25k now.i change oil once a year even if I dont cross 6000 kms between changes.
« Reply #15 on: January 09, 2018, 08:53:57 AM »
I am amazed you don't see any fur on the plug . Oh well , You must be giving the beast an easy life  ;)
cruiser13
« Reply #16 on: January 09, 2018, 08:56:16 AM »
Yes.that is true..She lives the easy rider life!
« Reply #17 on: January 09, 2018, 10:11:48 AM »
Mine has 65,000 kms.
Yes, fur on the tip of my magnetic sump plug from the very first oil change.
I think I have a tendency to over tighten my chain though. Ive since learned to relax. Literally.
« Reply #18 on: January 09, 2018, 10:40:20 AM »
I learnt that my very first chain and sprocket change (too much tension on chain) .....from you  :)
Should be almost touching swingarm (20-30mm)
Thanks .
« Last Edit: January 09, 2018, 10:43:33 AM by spit051261 »
