  • January 17, 2018, 09:20:54 PM
Pages: 1 2 [3]
Author Topic: Front cylinder colder than rear ????  (Read 714 times)
  • Online Online
Re: Front cylinder colder than rear ????
« Reply #20 on: January 09, 2018, 05:16:53 AM »
Rjbez,
That's one of the models with the more modern coil design. They're a branded coil. Delphi. Less likely to be an issue. If your suspicions lead you to think spark, then start with the leads and boots.
« Reply #21 on: January 09, 2018, 05:54:12 AM »
Rjbez,
Have you taken the throttle plate off yet , the one that converts it to full power :D
Nothing to do with the fault but it will put a smile on your face when you finally sort it out .
Glad to know it is your bike . All we need now is pictures when it's running sweet again  :)
Looks like we have another member to partake in all the fun and games here  8)
« Last Edit: January 09, 2018, 08:10:19 AM by spit051261 »
2010  GT650EFI  in black.
« Reply #22 on: January 09, 2018, 08:11:20 AM »
Rjbez,
I still think it's air buddy .
Rjbez
« Reply #23 on: January 09, 2018, 05:42:57 PM »
Rjbez,
I did take the oppertunity to remove that plate whilst I was putting the engine back together yes :) so very much looking forward to experiencing the difference when I get it running right !! And yes pictures will follow at completetion ;)
Growing up..
 just means being able to afford bigger toys !
  • Online Online
« Reply #24 on: January 09, 2018, 09:05:32 PM »
Rjbez,
Thanks for updating. Keep us informed how it goes buddy.
« Reply #25 on: January 10, 2018, 03:08:32 AM »
Pretty sure he will get it all sorted today .
He seems to know what he is doing  ;)
Rjbez
« Reply #26 on: January 10, 2018, 06:40:05 AM »
“Seems to know what he’s doing” ... jeez that’s a powerful statement you got there mate ;) hahah couldn’t get around to the bike today unfortunately.. looking Friday Saturday missions at this stage
Growing up..
« Reply #27 on: January 10, 2018, 06:55:45 AM »
You have a few new things to try .
Sure you will get it sorted and then you can give it a good blast , unrestricted  8) 8)
I thought you were a mechanic remember so I had an idea you knew what you were doing  ;D
Could always upload a video of the bike under fault conditions here .
http://tinypic.com/  is not a bad hosting site .It may give people more knowledgeable than myself a better idea of what's going on .
« Last Edit: January 10, 2018, 07:07:11 AM by spit051261 »
Rjbez
« Reply #28 on: January 12, 2018, 10:07:52 AM »
:UPDATE:
so managed to get down to the bike this afternoon to go tinker on. had bike running for about 15min, spraying around the rubber seals but didnt notice any differences. i double checked timing front and rear and comfirmed that both were correct and as per. checked clearances again.. all well within spec. did another compression and both cylinders are sitting out at 150psi.....  ???
found a fault code for the thermostat on the bike.. i believe it was 018 ? so was trying to get a reading with the mechanic mates meter but i will try with my own meter  tomorrow to confirm that there is an open circuit. should be getting between the 0.111kohm and 5kohm but just getting open circuit.
tried switching injector plugs around but all that achived was flooding the engine  :'( so will pull the injectors out tomorrow and give them a clean and try again with the plugs back to normal. otherwise. i will try reattatch my dodgy clutch cable and take it for a bit of a ride round the streets to see how it goes..
thats all for today
Growing up..
Pages: 1 2 [3]
