  • March 20, 2019, 03:09:56 PM
Pages: [1] 2 3 ... 24
Author Topic: 2013 GT650R  (Read 7484 times)
madhatter
2013 GT650R
« on: January 17, 2018, 06:59:44 AM »
Photos of my baby
https://imgur.com/a/SvQLN
UPDATED ALBUM 7/24/18:
https://imgur.com/a/65MzCkU
Video of my new exhaust;
https://streamable.com/0jf6g
« Last Edit: July 24, 2018, 09:32:25 PM by madhatter »
Re: 2013 GT650R
« Reply #1 on: January 17, 2018, 10:43:27 AM »
On the right side of the engine casing is a small round piece of glass.
There is a high and a low level indicator beside the glass. Holding the bike level, you should see your oil level somewhere between the two.
These bikes take 3.6L of oil if you are changing the filter at the same time, 3.4L if not. I would recommend always changing the filter and oil together.
Question, why did your bike have no coolant? This is not an idle question. This is a leading question. No coolant is most likely a symptom, not the root cause of the problem.
Death666wish_
Re: 2013 GT650R
« Reply #2 on: January 17, 2018, 09:46:05 PM »
Sorry to highjack the thread for one second here, but 3.6 and 3.4 sounds kind of extra to me, I always use 3 liters with or without a filter, always had it at full through the glass.
Climb the ladder of success!
madhatter
Re: 2013 GT650R
« Reply #3 on: January 18, 2018, 12:33:12 AM »
Honestly I got the bike about two months ago so I'm assuming the guy previously and I just noticed it now just cause it was getting hotter and he cold ND hot on my speedo was going up which never happened so I looked into the coolant and none or barely in there so that's why I'm asking what color to put or what exact bottle to buy for my exact bike
I can't seem to find the manual for my specific bike
Death666wish_
Re: 2013 GT650R
« Reply #4 on: January 18, 2018, 12:58:30 AM »
The coolant in my bike is green, is it correct or not I have no idea, but it's working so far!
madhatter
Re: 2013 GT650R
« Reply #5 on: January 18, 2018, 01:28:11 AM »
Haha sexy bike bro mine looks the exact same and I'll look into it more thanks for letting me know
Re: 2013 GT650R
« Reply #6 on: January 18, 2018, 02:08:57 AM »
Mine is also green. Any ethylene glycol based coolant will do.
Re: 2013 GT650R
« Reply #7 on: January 18, 2018, 06:30:27 AM »
Just changed my oil and filter on my GT650EFI and it's probably the same engine as yours .
It will take 3.2L of oil .
Easiest way to to do it , get a cheapo plastic  measuring jug and tip out 800ml and add the rest of a 4L oil container (you can buy it in a 4L container) to your bike . Oil level should be spot on .
madhatter
Re: 2013 GT650R
« Reply #8 on: January 18, 2018, 06:35:23 AM »
What about coolant? I'm about to put some green into my bike rn.
Re: 2013 GT650R
« Reply #9 on: January 18, 2018, 06:51:31 AM »
Just buy some pre-mixed coolant from an automotive store . Anything with ethylene glycol in it should be fine .
Any auto coolant will be fine . Coolant is coolant . It's obviously a bit different for engine oil where bike specific oil is recommended.
You can even buy neat coolant and mix it yourself with distilled water (not tap water).
