  • March 24, 2019, 12:43:05 PM
Author Topic: Ecu Cut  (Read 664 times)
jasondotcom
Ecu Cut
« on: January 24, 2018, 11:11:51 PM »
Hey guys.
So just the other day I was chatting with some dudes and the topic of "ecu cut" came in. I was informed that this bike can be tuned in a way whereby the rev limiter is removed and the new limiter comes in at 13,000 rpm.
Then I counter checked this with my chief mech at the bike's dealership and HE said that same thing too.
I questioned things like why factory rpm limiters come in below 11k rpm and why after being removed the limiter comes in at 13k rpm? He said by design it's rev limit is 13k rpm. The lower rpm set was due to emissions standard in some regions. On top of this, after "ecu cut" is made the bike will ride better due to better throttle response and faster pickup and better fuel efficiency and of course more usable power till 13k rpm.
Really? Anyone????
« Last Edit: January 24, 2018, 11:14:10 PM by jasondotcom »
Re: Ecu Cut
« Reply #1 on: January 25, 2018, 03:40:01 PM »
You mean the thread stickied at the top of this forum titled : Removing the flat spot - CDI Wire cut walkthrough with photos?
jasondotcom
Re: Ecu Cut
« Reply #2 on: January 26, 2018, 04:54:34 AM »
I thought that applies to carburetor versions only?
Re: Ecu Cut
« Reply #3 on: January 26, 2018, 09:24:22 AM »
Thats correct but you did not tell me you had an EFI bike.
This will not work on EFI and I think you would have to program an new ECU (did someone say OLEG was able to reprogram them?). Or build your own map for an aftermarket one.
« Last Edit: January 26, 2018, 03:25:48 PM by Joss »
jasondotcom
Re: Ecu Cut
« Reply #4 on: January 26, 2018, 02:28:25 PM »
Ok my mistake. Yes it's for EFI.
Btw, regards to my top post. Any comments?
jasondotcom
Re: Ecu Cut
« Reply #5 on: January 29, 2018, 02:01:33 AM »
Nobody?
Re: Ecu Cut
« Reply #6 on: January 29, 2018, 02:31:00 AM »
Jason,
Doesn't sound right.
Might have applied once upon a time to the carby versions, but doesn't sound correct for an EFI model.
If you really want this to happen, you are going to need to reprogram the ECU. This is not a simple task.
Re: Ecu Cut
« Reply #7 on: January 29, 2018, 04:02:34 AM »
Sounds like someone was yanking your chain.
jasondotcom
Re: Ecu Cut
« Reply #8 on: February 05, 2018, 04:03:39 AM »
Whether someone is yanking my chain or not but honestly i have seen it done not the tuning or mod process but more like its done as in done. The factory rev limit is moved to 13,000 rpms. I saw it with my own eyes i was like 'wow'....really?
Benefits gained from this is mainly lighter and faster throttle and speeds, better fuel consumption and higher top speed due to higher rpm limits.
Re: Ecu Cut
« Reply #9 on: February 05, 2018, 04:11:19 AM »
If you get a higher rev limit form cutting a cable then you've probably disabled the rev limiter.
I'm not sure how any of the benefits listed would be gained from deleting the rev limiter.
 If I remember rightly the 250 won't rev to 11,000 in top anyway, removing the limiter is unlikely to help.
might be worth reading this ---> http://korider.com/index.php?topic=10368.0
« Last Edit: February 05, 2018, 04:13:04 AM by stigger »
