  • March 24, 2019, 11:54:30 AM
Author Topic: Sporcket change, better acceleration  (Read 365 times)
BalintHU
  • App developer
« on: February 10, 2018, 08:41:11 PM »
Guys, i would like to adjust the bikes gearing ratio.
Mostly i ride 50-60km to get into  the hills, then I'm cornering.
I would like to get a bit more power, without a big cut on my top end.
If i go down one teeth at the front sprocket, and one teeth up at the rear sprocket, does it help to me? (Or it wont not be a significally sensible change.) If i try this should i change my chain(Stock)?
Any other idea what should by the best sprocket change to keep my top speed and crusing speed as near to the stock as it possible and make the bike a bit more playful?
Thank you!
Btw, i didnt bought tha 650's shock, I've ordered the new KYB shock. I hope it will be good, and a bit stiffer than the old stock.
Re: Sporcket change, better acceleration
« Reply #1 on: February 14, 2018, 02:09:09 PM »
Changing the front is drastic. Do you enjoy changing gear a lot?
BalintHU
  • App developer
« Reply #2 on: February 15, 2018, 11:06:53 PM »
What does it mean? How much top end will be lost? I thought / calculated there will be ~400-500 rpm more at the same gear and speed if i put up the 13 teeth sporcket.
Any way to sacrafise some top end for a better acceleration?
I Up and Downhill a lot because live near to a "small mountain" and there are many really cool serpentines. (That was the reason why i had to change the old shock abs, finally installed a brand new KYB "GT250RC", this one isnt filled with oil, the sticker tell it has Nitrogen Gas, wow. O.o)
« Reply #3 on: April 16, 2018, 12:43:04 AM »
Try just changing the rear sprocket first and see how that goes .
One step at a time .
Cloud is right , it's a bit drastic what you plan on doing .
BalintHU
  • App developer
« Reply #4 on: April 16, 2018, 05:43:07 AM »
Okey thanks, to all!
My actual chain set doesnt have too much left.
Next time Im going to buy a stock and a +2teeth rear.
