  • February 24, 2019, 02:49:57 AM
Author Topic: gv250 how to bypass kickstand switch  (Read 738 times)
Re: gv250 how to bypass kickstand switch
« Reply #10 on: March 12, 2018, 11:03:31 AM »
If I EVER saw anyone using one of those in work , they would be hung , drawn and quartered  >:(
I agree, but they have their uses and in this instance it is ideal as a temporary measure to test if the SSS is the problem by making an easily removable bypass.
« Reply #11 on: March 13, 2018, 10:32:35 AM »
One other thing has occurred to me - I had a breakdown on the Hyo, when I totally lost power, and it turned out to be the connector on the back of the main fuse.  Not the fuse on the front, but the connector on the back - it had worked loose.
Might be worth checking, in case that is starting on yours and causing the occasional cut-out.
paul gv250
« Reply #12 on: March 15, 2018, 01:40:54 AM »
Thanks for all the help & advise guys.. I'll definitely be on the lookout for that connector any one got any ideas what gauge wire is used?  Just having a look it looks like it's either 12 or 14 awg
