  • April 25, 2019, 03:27:42 AM
Pages: [1] 2 3
Author Topic: GT650 Fork and triple clamp dimensions  (Read 1045 times)
ruckusman
« on: March 09, 2018, 01:00:10 PM »
Hey Guys,
Looking for a triple clamp for a project bike and the GT650 setup looks like it may work.
Anyway I need the outer fork tube diameters at both of the triple clamp mounting points, the triple clamp offset and the width between the fork centres.
thanks
Glenn
2turbos
Re: GT650 Fork and triple clamp dimensions
« Reply #1 on: March 09, 2018, 04:34:59 PM »
Measured as close as I could get it:
Top clamp dia=51mm
Bottom clamp dia=54mm
ruckusman
« Reply #2 on: March 09, 2018, 10:18:36 PM »
Top clamp dia=51mm
Thanks 2turbos, much appreciated.
Are you able to measure the offset and fork centre to fork centre distance also?
BTW - the info gathered will be added to this database which is to help anyone doing a fork or front end swap know which parts are compatible
http://litetek.co/Guide_USD_ForkDatabase.html
peace out
Glenn
2turbos
« Reply #3 on: March 10, 2018, 01:31:31 AM »
I might be able to approximate those measurements, I'm afraid I can't get measurements I could trust. Sorry!
« Reply #4 on: March 12, 2018, 12:17:17 PM »
Top clamp dia=51mm
peace out
Glenn
Ruckusman , I owe you an apology .
Sorry for having a go at you .
You obviously want to help people and I made a mistake . No good coming out with excuses , I fooked up.
Hope you can let this slide and let us carry on as normal .
If you can't , I understand .
Paul
ruckusman
« Reply #5 on: March 12, 2018, 12:37:13 PM »
Top clamp dia=51mm
peace out
Glenn
Paul
Hey Paul,
All good, I won't pretend I wasn't pissed but I kept quiet in case it was out of character for you.
It takes a lot of courage and maturity to apologise so you've more than redeemed yourself by doing that.
If you have opportunity to make some more measurements I'll get Blair to make a Hyosung section on the fork swap table.
Obviously a lot of the information on a lot of entries is incomplete, but a few simple details can be sufficient for people to know whether to investigate further.
Out of interest how do you find the forks?
I've been searching over the weekend, lots of hyosung parts out there and very well priced, tempted to get a set and see if I can fit cartridge internals from other Kayabas
« Reply #6 on: March 12, 2018, 12:47:20 PM »
Not too sure about the forks , the suspension does not seem right on them .The suspension seems bad all around if I am honest . I also think the brakes need a lot more attention than the suspension .
If you can give a precise list of the measurements you want , I will do my best .
I am an engineer / electrician by trade but I don't have accurate measuring devices at home .
They are all at the mine site I work at .
I will do my best though .
Cheers buddy  :)
« Last Edit: March 12, 2018, 12:57:41 PM by spit051261 »
ruckusman
« Reply #7 on: March 12, 2018, 12:59:01 PM »
Cheers buddy  :)
When you say bad, affecting the steering & handling? - I may have a potential solution if it's a certain symptom.
I'm considering the forks for a 29 year old FZR250 at this stage, which were for Japanese domestic market only with average rider weight a lot less than me, so from my perspective there is bad and there is BAD.
A tape measure will suffice for accuracy, fork length, fork spacing on the triple clamp and triple clamp offset are the basics.
There's a full list of all of the measurements on the litetek site http://litetek.co/Guide_USD_ForkDatabase.html
There may be some worthwhile info there for you regarding brake calipers as I've encountered other people looking for alternatives/upgrades
« Reply #8 on: March 12, 2018, 01:17:50 PM »
OK buddy ,
It's getting late here in OZ but I will take measurements of everything tomorrow  ;)
As far as the suspension , I can't put my finger on it but it just seems like it should be definite and more certain if you know what I mean .
I can live with the suspension but the brakes really need looking into . They are shocking as in not stopping very well at speed and rear brake is useless .
« Last Edit: March 12, 2018, 01:21:04 PM by spit051261 »
« Reply #9 on: March 12, 2018, 01:30:19 PM »
Unless you do the upgrade  ;) ;) ;) ;) ;) ;) ;) ;)
Pages: [1] 2 3
