  • May 24, 2019, 04:27:35 AM
Pages: [1] 2 3 ... 5
Author Topic: FI Indicator on  (Read 1898 times)
ilyasbaig
FI Indicator on
« on: April 06, 2018, 07:22:31 PM »
hi guys.had started my bike(ST-7) after a few weeks and the FI indicator is on continuously. is it a serious fuel injection issue? please advice
Re: FI Indicator on
« Reply #1 on: April 06, 2018, 09:43:05 PM »
You should research how to put your ECU into diagnostic mode. Also called 'dealer mode'. It will output a code. The code is sometimes a series of flashing lights, or sometimes a number on the dashboard.
This number is a code for what the ECU is noticing as being abnormal. If you can find the code, we can translate it for you.
Re: FI Indicator on
« Reply #2 on: April 07, 2018, 05:45:26 AM »
Why do you say fuel injection issue ?
There are numerous issues that could give you a fault light .
Re: FI Indicator on
« Reply #3 on: April 09, 2018, 06:30:42 AM »
Try charging up the battery using an external smart charger.
Lead acid batteries self discharge at a rate of 1% per day.
Two months of no riding and you are down to half charge.
A low voltage will upset the readings from various sensors to the ECU.
Once the FI light is triggered it will remain on even if the error no longer exists, until you turn the key off and back on again which clears the error codes.
If the error still exists after the key on-off cycle the FI will light up again.
ilyasbaig
Re: FI Indicator on
« Reply #4 on: April 09, 2018, 10:32:02 AM »
Thanks...will try that..but if anyone can help me in how to get to diagnostic mode ,would be great...
Sent from my iPad using Tapatalk
ilyasbaig
Re: FI Indicator on
« Reply #5 on: April 09, 2018, 10:33:35 AM »
Battery seems fine..but will charge externally as you say.... thanks
ilyasbaig
Re: FI Indicator on
« Reply #6 on: April 09, 2018, 10:34:21 AM »
That’s my ignorance...if you could shed more light would be great.
Re: FI Indicator on
« Reply #7 on: April 09, 2018, 11:41:44 AM »
I'm sure there is a link kicking around with all the ECU codes and if you can't find it, suggest giving upside_down a PM. He will know for sure.
ilyasbaig
Re: FI Indicator on
« Reply #8 on: April 09, 2018, 03:12:05 PM »
Yup USD is a great source
Re: FI Indicator on
« Reply #9 on: April 10, 2018, 08:57:30 AM »
Download the manuals.
