  • May 24, 2019, 04:14:30 AM
Pages: 1 [2] 3 4 5
Author Topic: FI Indicator on  (Read 1897 times)
Re: FI Indicator on
« Reply #10 on: April 10, 2018, 03:35:42 PM »
Download the manuals.
Perhaps he can't find the information he needs .
Always easier asking someone else to do it for you  ;D
I am not speaking for myself here BTW .
ilyasbaig
Re: FI Indicator on
« Reply #11 on: April 11, 2018, 12:30:11 PM »
I have the manual.. thanks downloaded it sometime back. Will revert back if in doubt..
Sent from my iPad using Tapatalk
Re: FI Indicator on
« Reply #12 on: April 12, 2018, 10:43:16 AM »
You keep asking away buddy and if I can help , I always will .
ilyasbaig
Re: FI Indicator on
« Reply #13 on: April 16, 2018, 07:39:44 PM »
Thanks spit
ilyasbaig
Re: FI Indicator on
« Reply #14 on: April 16, 2018, 07:42:39 PM »
hi guys.had started my bike(ST-7) after a few weeks and the FI indicator is on continuously. is it a serious fuel injection issue? please advice
Try charging up the battery using an external smart charger.
Lead acid batteries self discharge at a rate of 1% per day.
Two months of no riding and you are down to half charge.
A low voltage will upset the readings from various sensors to the ECU.
Once the FI light is triggered it will remain on even if the error no longer exists, until you turn the key off and back on again which clears the error codes.
If the error still exists after the key on-off cycle the FI will light up again.
Battery seems fine..but will charge externally as you say.... thanks
Battery fully charged.but still the FI light comes on a few secs after I start the engine. Just wanted to know how to get into dealer mode..nothing is mentioned in the service manual
Re: FI Indicator on
« Reply #15 on: April 16, 2018, 11:38:46 PM »
Sorry , can't help .
I have a different ECU which just requires shorting 2 wires , according to everyone here that is .
ilyasbaig
Re: FI Indicator on
« Reply #16 on: April 17, 2018, 10:23:10 AM »
Thanks spit..hope hylife or UsD come up with something
Re: FI Indicator on
« Reply #17 on: April 17, 2018, 09:27:17 PM »
I have heard so many different things in the past..
No one reports back to say what works for sure.
I think that you definitely have the short the connector, plus one maybe one of the following:
1. Turn the key to the ON position 5 times within 3 seconds.
or
2. Turn the bike to ON while holding down the select button.
If you have been successful, either the FI light will start flashing, or the dash will display a code.
ilyasbaig
Re: FI Indicator on
« Reply #18 on: April 18, 2018, 11:18:24 PM »
or
Thanks UsD...will check it out(options 1 n 2).. but what pins to be shorted in the connector.
ilyasbaig
Re: FI Indicator on
« Reply #19 on: April 19, 2018, 03:03:19 PM »
Hi guys... thanks UsD.. Tried the select switch and toggling of ignition switch...seems to work and got a blinking FI.. Ten blinks and 1 blink and 1 blink and then 3 blinks.. So it was 10-1-1-3... service manual doesn't have anything like 10--- all codes start with 0..so should I infer it as 0113? Plz advice if i'm missing out on anything... the service guys don't even have an ecu tool kit..so trying it on my own..
Pages: 1 [2] 3 4 5
