  • March 20, 2019, 02:43:20 PM
Pages: 1 2 [3] 4 5
Author Topic: FI Indicator on  (Read 1748 times)
Re: FI Indicator on
« Reply #20 on: April 19, 2018, 09:14:29 PM »
Sounds good to me!
113 is your code, which equals Intake Air Temperature sensor.
ilyasbaig
Re: FI Indicator on
« Reply #21 on: April 19, 2018, 09:35:24 PM »
Thanks a lot...UsD.... will follow thru with service manual now
Sent from my iPad using Tapatalk
Re: FI Indicator on
« Reply #22 on: April 20, 2018, 07:17:19 PM »
Glad you found it buddy.
Can you keep the thread updated and let us know how it goes? It always helps others in the future... ;)
ilyasbaig
Re: FI Indicator on
« Reply #23 on: April 20, 2018, 07:35:57 PM »
Thanks Sid..well the manual says to remove the fuel tank and you can find the sensor...will take I to a local mechanic to remove the fuel tank...the tank is full though have to empty it I guess. One question.. what are the adverse effects of such a failed sensor.? Can I still ride on?
Re: FI Indicator on
« Reply #24 on: April 20, 2018, 08:46:36 PM »
I think the worst it could do is a lack of performance, or slightly rough running?
Nothing too drastic I imagine.
Can you not prop the tank up on the supplied stand to access the sensor?
You may not have to remove it entirely.
« Last Edit: April 20, 2018, 08:48:30 PM by Sid »
ilyasbaig
Re: FI Indicator on
« Reply #25 on: April 21, 2018, 07:17:48 AM »
Thanks Sid, Will try to do that...
Re: FI Indicator on
« Reply #26 on: April 22, 2018, 02:37:37 AM »
I took my tank off with a stack of fuel in it and only spilt a bit. Just makes sure you have organise somewhere to put it on the floor before removing it.
It's piss easy to remove and you should be able to do it yourself.
ilyasbaig
Re: FI Indicator on
« Reply #27 on: April 22, 2018, 08:47:04 PM »
Thanks spit will be doing it soon
Re: FI Indicator on
« Reply #28 on: April 23, 2018, 02:20:36 PM »
Remove seat and bolt for tank (bolt is under front of seat).
Lift it up a bit and remove all hoses. They have quick connect fittings so easy.
There are 2 rubber bungs, on front of tank so make sure you get those out with tank.
Put it down on some wood and absorbant rags (soak up spills and stop tank from getting scratched).
Go to work and reassemble.
Easy
« Last Edit: April 23, 2018, 02:24:31 PM by spit051261 »
ilyasbaig
Re: FI Indicator on
« Reply #29 on: April 28, 2018, 11:33:21 AM »
Easy
Tried taking the tank off.. the bolts and the rubber bungs..was difficult to remove the tank totally off the chassis so wanted to take it to mechanic..while fixing back the bolt..one of the bolt gave way..guess wrong threading and excessive force by me...now foot in mouth situation..tank secured on 1 bolt only..safe to ride till the service workshop.? Or hire a tow vehicle..
Pages: 1 2 [3] 4 5
