  • July 20, 2019, 02:38:55 PM
Pages: 1 [2] 3 4 ... 6
Author Topic: Cold start idle miss/clunk.  (Read 2319 times)
CR
Re: Cold start idle miss/clunk.
« Reply #10 on: April 23, 2018, 10:30:55 AM »
A possibility for sure
CR
« Reply #11 on: April 24, 2018, 05:54:27 AM »
Stator side is like new. Clutch basket is tight, everything looks perfect. Chain tensioners possibly.
« Reply #12 on: April 24, 2018, 07:02:46 AM »
is the clunk from front or rear cylinder ??
easy thing to test, swap the coil packs around and see if the opposite cylinder starts knocking.
CR
« Reply #13 on: April 24, 2018, 07:10:38 AM »
In all honesty, sounds like its coming from the lower case near the front chain sprocket. But thats all nice and tight.
« Reply #14 on: April 24, 2018, 06:22:18 PM »
Noises can be half impossible to trace sometimes and very misleading.
If it was the cam chain rattling, then surely it would sound like a rattle? This sounds like an irregular dull knock.
Anyway, back to the point (kind of). I thought I had a suspension component failure on my car. I was convinced the noise was coming from underneath the car under the passenger seat area. Turned out it was the tailgate knocking where the catches had come loose!! - so nowhere near where I thought.
Sounds travel in mysterious ways!
CR
« Reply #15 on: April 24, 2018, 10:26:39 PM »
Yeah, doesn't sound like a rattling chain.  I'll keep digging.
« Reply #16 on: May 05, 2018, 04:03:36 PM »
Hi mate,
Any updates on this?
CR
« Reply #17 on: May 05, 2018, 10:50:06 PM »
Not as yet. I'll put some time into it today.
CR
« Reply #18 on: May 06, 2018, 11:14:44 AM »
Checked TPS values, error codes, and went through some electrical connections. No joy. Only got one hiccup on start up, but still a hiccup. Does it with sidestand up or down. Clutch lever in or out. I'll try again next weekend. Might swap coils over as suggested to see if anything changes.
« Reply #19 on: May 06, 2018, 12:15:20 PM »
To eliminate the sssssss, try shorting it out.
Just because your sssssss is up, doesn't mean it's working
I don't think it's that though.
Coils seem like a possibility.
« Last Edit: May 06, 2018, 12:17:51 PM by spit051261 »
