  • January 19, 2019, 03:24:53 PM
Author Topic: Location of cable for diagnose  (Read 297 times)
Doka
« on: April 28, 2018, 05:59:05 PM »
Hi, i need help. I cant find cable for diagnose? I drive GT250RN 2010 year
Doka
Re: Location of cable for diagnose
« Reply #1 on: April 28, 2018, 08:40:18 PM »
Ok, I find cable. And displey show me only CHE, nothing more. What che means?
« Reply #2 on: April 28, 2018, 10:43:01 PM »
Welcome to the forum .
Why don't you post some pictures of your bike . It's a good way to get to know everyone .
You will find this is the best place for anything Hyosung related .
BTW is your bike starting ?
“CHEC” : The LCD panel indicates “CHE”  when no communication signal from the ECU is received for 3 seconds.
For example, The ignition switch is turned “ON” position, and the engine stop switch is turned “OFF” position. In this case, the speedometer does not receive any signal from ECU, and the panel indicates “CHE”. If “CHE” is indicated, the LCD does not indicate the trouble code. It is necessary to check the wiring harness between ECU and speedometer couplers. The possible cause of this indication is as follows, Engine stop switch is in “OFF” position. Ignition fuse is burnt.
« Last Edit: April 28, 2018, 10:54:11 PM by spit051261 »
« Reply #3 on: April 29, 2018, 10:32:52 PM »
Hello Doka,
CHE means no error.
The ECU does not remember error codes. Once you turn the bike to OFF, it forgets the error.
If you want to see the code, wait for the FI light to come on, then short the diagnosis cable.
« Reply #4 on: April 30, 2018, 12:22:01 AM »
Hello Doka,
CHE means no error.
CHE will also come on if the stop switch is activated (or faulty) and the key is turned try to start bike .
That is why I asked if the bike starts .
« Last Edit: April 30, 2018, 12:26:20 AM by spit051261 »
Doka
« Reply #5 on: May 10, 2018, 05:14:37 PM »
Aha, ok. Thanks so much. The bike is working correctly. I only wont too sea if there is some faulty. I will post pictures later of my bike
« Reply #6 on: May 10, 2018, 05:28:33 PM »
 :o
If there is a fault , it will show up on the display .
Don't go looking for trouble if there is none .
Be happy your bike is working and leave it at that .
If it ain't broke , don't try to fix it  ;)
« Reply #7 on: May 11, 2018, 05:25:47 AM »
Sounds like what my mum used to say to me when I was a little boy. “Stop touching it or you’ll go blind!”
« Reply #8 on: May 11, 2018, 07:37:33 AM »
Sounds like you didn't take her advice and you didn't end up going blind so bit of a result for you  ;)
« Last Edit: May 11, 2018, 07:39:43 AM by spit051261 »
