  • February 24, 2019, 02:21:44 AM
Author Topic: 2013 efi piglet random cuts out while slowing down  (Read 389 times)
paul gv250
« on: May 13, 2018, 11:55:04 PM »
HI guys,
Still have this random issue with efi randomly cuts out while slowing down.  I've checked the spark plugs & they're OK, I've thrown in the whole bottle of efi additive, changed the R/R.  lubed the clutch cable, changed the kickstand switch
This only happens when I pull in the clutch while slowing down/stopping. or stop start in traffic. I'm always able to start the bike right away, bike idles at 1800 but it does sound that 1800rpm is a bit low.  The idle does sound like it's too low.  I've looked at how to adjust the idle, as I'd like to bump it up slightly to 2000rpm & hope that this stops the random cutting out.  The service manual I've downloaded states not to adjust the idle & it shows 2 screws where each of the idle adjustments are on both sides of the bike.  My bike only has 1 on each  side (there's no hole for a 2nd screw as per the manual).
How do you adjust the idle?  I'd be more than happy to upload photos but I can't find the option to attach photos :(
Any help would be appreciated as I've no local dealer & no garage near me wants to touch hyo's (they've a bad rep in Canada)
Re: 2013 efi piglet random cuts out while slowing down
« Reply #1 on: May 27, 2018, 01:45:50 PM »
Late I know, but the idle should be approx. 1500rpm.
Sounds like the gear selector switch (left side of engine crankcase, see manual) or the clutch lever switch.
« Reply #2 on: May 29, 2018, 05:10:36 PM »
That is spot on with the gear selector switch which could be a dodgy switch or even a dodgy ground on your bike.
I had the same thing but it should bring up the FI light whilst doing this , it did on my bike .
It will just cut the engine out which it did when I was doing over 175 K's which is not funny .
C31 is the code you should get .
« Last Edit: May 29, 2018, 05:12:08 PM by spit051261 »
