  • January 19, 2019, 03:24:49 PM
Author Topic: Clutch wont fully disengage  (Read 208 times)
Bweat
« on: May 16, 2018, 03:26:55 AM »
I have a 2007 GT650R. I have had power issues since i purchased the bike. This past week i tore the bike apart looking for the culprit. I believe i found the issue which is the clutch will not fully disengage. The lever will not spring back after i release the clutch.  Its basically item 20 wont spring back and and its the shaft item 23ish that wont come back unless i manually move it from the photo. I have searched google and forums but cant seem to figure it out. Is there supposed to be a spring that brings that shaft back to engage the clutch? Any help would be much appreciated. http://www.alpha-sports.com/hyosung/GT650_S_R/10.gif
Re: Clutch wont fully disengage
« Reply #1 on: May 16, 2018, 06:06:28 AM »
There is no external spring or such.
Basically the springs on the pressure plate hold the tension on the clutch to stop slipping, when you pull your lever a rod pushes against those springs and releases the tension on the clutch plates.
From memory i think there is a little adjuster inside the pressure plate for fine tuning.
So your either gonna have an issue with the clutch cables/the internal adjuster or your clutch pressure plate springs are shot. Thats all there really is to engage/disengage the clutch.
