  • January 19, 2019, 03:38:32 PM
Author Topic: fuel injector  (Read 167 times)
Galacticaone
fuel injector
« on: May 25, 2018, 05:51:48 PM »
Hello
Changed out a bad injector on the front cylinder.  It tested good at an r value of 12.5 ohms.  Suspect the r value might change when it gets hot.  It would idle properly when cold, once it started to warm up the idle would jump and drop to 1200 or so rpm and then jump back up again to normal.  It would cycle like this on idle.
Changed out the injector, problem solved, stays steady on idle at 1500-1700rpm.
