  • June 02, 2020, 12:02:37 PM
Author Topic: Pre efi - GV 250 Fuel Lines  (Read 1245 times)
hogrider
Re: Pre efi - GV 250 Fuel Lines
« Reply #10 on: June 07, 2018, 12:02:01 AM »
Sorry about the late reply, did not get to look at the motorcycle for a while.
Had clearances of almost 0.20mm on in and 0.25mm out tappets (those are the two feeler gauges I have).
For front cylinder, I tried with lobe positions 180 degrees apart at TDC, Exhaust at 9 o' clock and in at 3 o' clock, but have been getting a different chatter when trying to start.
Manually turning the crankshaft stops at one point, starter trips beyond but cant manually turn a full circle now.
I initially thought that it broke a push rod as it sounded like some loose part hitting sides, but the pistons are moving.
I hate pulling everything apart now that I have one cylinder starting by itself, sparks were revving to 4700 rpm on full throttle, the chains are tight on the cam gears, but there is something loose somewhere :-(
Hopefully will get some time to take it somewhat apart on Saturday, till then spinning mental gears
Christianleon266
« Reply #11 on: June 07, 2018, 03:08:54 AM »
Those clearances are either ultra bad or mis typed. Noise while rotating and getting stuck.. could it be your turning the crankshaft the wrong way, causing the starter to engage and chain to bind. Bad tensioner?
From what i can decipher, you adjusted clearances via shims and now the cylinder wont turn by hand? is it a mechanical resistance or pressure resistance? spark plugs removed when cranking by hand/ starter?
2007 Kawasaki KX250F
1984 Yamaha Virago
1982 Honda V45 Sabre
1996 Kawasaki ZX6R
2009 Kawasaki Ninja 250
1982 Kawasaki KZ750E
2005 Suzuki M50
1983 Honda Goldwing Aspencade
2007 Hyosung GT250R
1991 Honda ST1100 (current)
hogrider
SOLVED: Pre efi - GV 250 Fuel Lines
« Reply #12 on: July 08, 2018, 03:16:16 PM »
The clearances were in spec for the intake (0.2mm) and exhaust (0.25mm) at the tappet covers,
The intake valves were staying open earlier at TDC and touching the piston.
I was following the service manual (3-54) with arrow positions 2 (exhaust) and 3 (intake) and that was not the case for the camshafts I had. I iteratively tried other markings on the cams and got the cylinder going with arrow 1 (exhaust) and 2 (intake) with intake opening right after TDC and exhaust happening afterwards.
Spark plugs are new NGK gapped to around 0.75mm, carb sucks in proper cycle.
I was able to install the airbox by using insulator wax and a spackling spatula to shimmy the rubber boots over the carb intakes. Did this without taking the engine off the frame :-)
In conclusion, I followed manual for clearance specs, and listened to piston movement and checked pressure to visualize what was happening.
Thanks for your help in getting it running.
