  • May 23, 2019, 10:03:53 AM
Author Topic: top class wiring  (Read 417 times)
top class wiring
« on: June 06, 2018, 05:53:18 AM »
Battery seemed to be on it's way out so last week , thought I would check it out .
Took reg off and low and behold , find this  :o
Changed it over to some decent connectors , checked stator (all good) and threw in a new reg which was just sitting around in my spares box .
Wonder if LX owned this bike before me  ;D
Quote from LX_SS after he dissed my connectors and said they were "overkill"  ;) (only pulling your leg)
"Nope not at all, thats still too good.
I request both wires placed in blue-tak and stuck against the frame. Nothing else ........"
Anyway , before and after .
Christianleon266
Re: top class wiring
« Reply #1 on: June 06, 2018, 06:30:56 AM »
Is that a weatherpack connector. lol your that much closer to an LS swap.
2007 Kawasaki KX250F
1984 Yamaha Virago
1982 Honda V45 Sabre
1996 Kawasaki ZX6R
2009 Kawasaki Ninja 250
1982 Kawasaki KZ750E
2005 Suzuki M50
1983 Honda Goldwing Aspencade
2007 Hyosung GT250R
1991 Honda ST1100 (current)
« Reply #2 on: June 06, 2018, 07:28:25 AM »
Is that a burn mark?! Holy crap that must have been stinking hot.
« Reply #3 on: June 06, 2018, 07:49:37 AM »
Unacceptable spitty, you must not use those connectors, they reduce failure rates and offer superior protection.
I request you remove them and go back to blue tak otherwise i might have to contact the chinese authorities :-P
« Reply #4 on: June 06, 2018, 07:51:48 AM »
Yeps  :o
That's part of the reason the new reg went in .
I will check it periodically to make sure it's OK but the stator is fine and with the wires just twisted together and taped , it wasn't pretty .
Edit...I also shot in another battery ground . You can see it in pictures with the red heat shrink on it .
You can't have enough good grounding points on these bikes with electrics from hell  ;)
Christianleon266
It's a DEUTSCH connector . Expensive but we use lots of them in work , wink wink .
They are the best connectors I have ever used TBH .
« Last Edit: June 06, 2018, 07:59:38 AM by spit051261 »
« Reply #5 on: June 06, 2018, 08:04:18 AM »
Some of the techs where I work are using them for devices in an operating theatre. The AMP brand ones stay dry at 3 bar.
« Reply #6 on: June 06, 2018, 08:09:27 AM »
As long as you put electrical grease in them , they will last forever .
« Reply #7 on: June 06, 2018, 08:23:33 AM »
Wow Spitty, that looks a heck of a lot safer now, good job.
I actually had a similar incident a while back on my Honda, someone had bodged a car 14v starter relay into the harness in exactly the same fasion as that wiring was on yours.
« Reply #8 on: June 06, 2018, 08:40:47 AM »
Probably not as safe as LX's lash ups  ;D but it will do .
« Reply #9 on: June 06, 2018, 09:03:35 AM »
Red heatshrink on a black ground wire, now thats more acceptable for bad color coding.
*golf clap for spitty*
now just change the connectors back to blue tak and your getting a pie in the mail. *warning pie may not be fresh on arrival*
