  • May 23, 2019, 10:08:05 AM
Author Topic: Engine reving  (Read 391 times)
Magnusy
Engine reving
« on: June 07, 2018, 11:16:19 PM »
Hello everybody.
First I'd like to mention that this is my first post here so I'm glad to be a part of this forum now.
I'm owning an `11 gt250r fuel injected and I'm having a little issue with it.
Sometimes when I come to a complete stop the engine revs to 2.5~3.5k for a few seconds then it goes back to idle. It is not doing it all the times, just when it wants to.
Usually it helps if I rev it up to around ~5k and it gets back to idle speed.
Any idea?
I will check the throttle cable first thing. If that looks ok I think this may be something injector related :( :o :o.
Let me know your thoughts.
Magnusy
Re: Engine reving
« Reply #1 on: June 13, 2018, 01:01:01 PM »
Up
Re: Engine reving
« Reply #2 on: June 13, 2018, 01:57:06 PM »
Could just be throttle cable sticking .
Dead easy to check mechanism on throttle body but you will have to remove fuel tank and air filter which is also very easy .
If you get stuck just shout out  :)
Always eliminate the easy stuff first before thinking the worst  ;)
« Last Edit: June 13, 2018, 02:00:04 PM by spit051261 »
Magnusy
Re: Engine reving
« Reply #3 on: June 13, 2018, 01:58:53 PM »
I checked the throttle cable by eye and it seems fine.
I also read a lot of forums and apparently this is a common issue for the efi version.
Some say that the revving helps the engine cool down.
Re: Engine reving
« Reply #4 on: June 13, 2018, 02:02:33 PM »
That is a new one on me but I am not saying you are wrong .
You need to check the throttle properly by checking the mechanism under the air filter and fuel tank .
Magnusy
Re: Engine reving
« Reply #5 on: June 13, 2018, 02:41:56 PM »
Do you have any idea if my bike has an fuel filter?
Couldn't find any info on this.
Re: Engine reving
« Reply #6 on: June 14, 2018, 05:17:39 AM »
No. Not on an EFI bike. Weird eh?  :o
Magnusy
Re: Engine reving
« Reply #7 on: June 14, 2018, 10:43:22 AM »
Wierd for real. I guess all the gunk goes directly to the injectors. I will look up to a good fuel system cleaner then, maybe that'll help
