  • April 26, 2019, 04:47:51 AM
Author Topic: Pop! Smoke... but everything still works...  (Read 737 times)
Zyton
Re: Pop! Smoke... but everything still works...
« Reply #10 on: June 13, 2018, 01:08:25 PM »
Sounds like a backfire out the carbs
Sent from my SM-G950F using Tapatalk
« Reply #11 on: June 13, 2018, 01:11:29 PM »
I concur
Short and straight to the point.
The way our readers like it  ;)
eliross
« Reply #12 on: June 13, 2018, 02:51:41 PM »
Oh it's definitely electrical. It reeked of burnt electronics and it fizzled and burned for a bit (why I booked it for an extinguisher). Hopefully I'll get the tank off tomorrow and I can explore further.
« Reply #13 on: June 14, 2018, 08:19:38 AM »
I just remembered my helmet traffic cam was on so here are some action shots for your entertainment
I could not stop laughing at this, I'm so looking forward to the next set of pictures  ;D.
Does the harness also run down the left hand side of the bike (sat on it) on the GV 650's too? If thats the case the smoke would be from the other side so it might not be the "main" harness.
eliross
« Reply #14 on: June 15, 2018, 03:31:10 AM »
I stand corrected! I decided to swap out the air filter while I had the tank off and, low and behold, the filter was cooked. To be fair it does smell like burnt electrics (I used to work in IT and I'm very familiar with this smell.) So it was a carb backfire, the question is is should I be concerned about one backfire on ignition and get the carbs cleaned, and valves and timing checked? I'm a little concerned about what was burning after the backfire. Thanks guys you've been a ton of help! Pics for entertainment. Just to remind you that's the engine facing side of the air filter
https://ibb.co/eqYsAJ]
« Reply #15 on: June 15, 2018, 04:49:44 AM »
Maybe you were going so fast that a static electrical charge built up on the filter and it electrocuted itself and surprised your bike so much that is sneezed? ;)
If it doesn't do it again, then just let it be. No point starting a fight with your bike.
« Reply #16 on: June 21, 2018, 08:07:26 AM »
A fight you probably won't win .
