  • March 20, 2019, 02:35:43 PM
Author Topic: gt250r Clutch  (Read 380 times)
Magnusy
gt250r Clutch
« on: June 17, 2018, 09:16:09 PM »
Hello,
Anyone knowing a sitte that sells a clutch kit for my '10 bike? I need the steel and friction plates plus the springs.
Also, I'm living in Europe so it'd be great if you know someone who send it here faster.
Does the first/last plate matter for this bike? Are they different?
Also, what are the torque specs.
Thanks!
Re: gt250r Clutch
« Reply #1 on: June 17, 2018, 10:03:00 PM »
http://hyosungsource.com have a really good range of spares.
Magusy, what's wrong with your clutch anyway? I can't recall having heard of a 250 clutch failing..
p.s. torque specs for the clutch spring bolts is 8Nm.
Magnusy
Re: gt250r Clutch
« Reply #2 on: June 18, 2018, 08:09:03 AM »
Hi,
My clutch is making a rumbling noise when I pull in the lever. It sounds like a bad car's flywheel when you press the clutch.
I investigated on internet and I think it's the clutch.
Another issue is that the clutch arm( the one that the clutch cable is moving) is very far out. Normally it has to stay at a 90% angle. Mine is stretched so much toward the cable.
Let me know your thoughts.
EDIT: I checked the link you provided. It amazes me that it is cheaper to buy the whole clutch assembly, bolts and clutch basket included than the repair kit.
Re: gt250r Clutch
« Reply #3 on: June 18, 2018, 10:11:53 AM »
That's the thrust bearing.
Re: gt250r Clutch
« Reply #4 on: June 18, 2018, 11:00:13 AM »
Welcome back Cloud!
Magnusy
Re: gt250r Clutch
« Reply #5 on: June 18, 2018, 01:24:35 PM »
The thrust bearing is the one behind the clutch basket?
Couldn't find a repair manual for 250r
